Question about Whirlpool Washing Machines
I have a awo 3761/5/s model and it keeps coming up on the display fh and the lights flash what does this mean
  • Whirlpool Master
  • 909 Answers
Unfortunately there are so many abriviations that one cant keep up.(not standardised). Best thing to do is do a manual check. Switch water off and check the filter. Clean it. Next, do a check and confirm that the drain pump is free of obstruction and free to turn.(loose). Get motor to spin by selecting spin and see if it does. If all those checks work out, it should function.
Posted on Jun 05, 2010
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
F and H keep coming up on screen
The information provided is general. For information specific to your washer please resubmit the question, including the model number.
The "F" is at the beginning of all error codes. This indicates the a Fault has taken place. The second number or letter indicates what the Fault is.
FH : Is displayed when no water has been detected entering the washer.
If the control has turned on the fill valve and after 8 minutes the flow meter has detected 10.5 gallons of water and not detected a pressure switch trip, the valve will be turned off and the failure code will flash in the display
Unplug the washer from its electrical source and wait for 30 seconds.
Replug the cord into the electrical source and try to start a normal cycle or a cancel drain cycle.
The machine should start the pump out mode and empty the water.
If, after 30 second, the machine has not detected water entering into the machine, the valves will be shut off and the failure code of FH will be displayed.
Check all hose connection and valves, both hot and cold, are turned on completely.
Verify that water is at the fill hose connections at the back of the washer.
The main control has sensed a component failure in the machine and will be needing a diagnostic visit for a possible repair or replacement.
Hope helps (remember to rating this free answer and leave a comment)
Sep 30, 2011 | Maytag EPIC MFW9700S Front Load Washer
After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Aug 02, 2009 | Washing Machines
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
You probably need a new heater element
Nov 25, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
145 people viewed this question
Dan Webster
Dan Webster
Sal De
