Question about Toshiba Satellite A25-S207 Notebook
Turning on problems..
When I put in the ac adapter and charge it until the battery icon turns green i try to turn it on but the plug in thing starts to blink orange, and wont turn on the laptop even if i dont have it charging it will do the same, i dont what to do to even try to fix it
  • Zach0212 Apr 10, 2008
    Its a toshiba satellite a25-s207
  • One Million Network Inc
    what laptop is it ?
  • Toshiba Master
  • 13,433 Answers
try removing the battery and plug in the AC adapter try to power up, what happens?
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you,
Posted on Dec 28, 2008
I have a toshiba laptop satellite L-300 that won't turn on. I tried unplugging AC and remove the battery and hold the power button for 30 sec. and plugged the AC back, i can see the green light at the...
Sep 03, 2011 | Computers & Internet
I had the same problem. This procedure from the "Technical Questions" section of worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Battery not charging? Help please.
How old is the battery? Usually, batteries only have 1 yr of life. It will start degrading when it is near its 1st year. You should consider that as well. You can try to take the battery out of the laptop and drain its power. Meaning, you would have to leave the computer without the battery and the ac adapter for at least 2 minutes. You can also press the power button while doing so to ensure its completely out of power. Next, plug in the AC adapter and turn your computer on without the battery (yes without the battery. This would check if your AC adapter is doing fine as well. If it does not turn on, you are having troubles with the AC adapter as well). After turning it on, allow windows to load and have the computer detect that it doesnt have a battery. You would see the icon that the battery is not connected. Next, turn your computer off and connect the battery. Unplug the AC adapter and turn the computer on. Wait until windows loads and then connect the AC adapter and see if you will still get the same message. If you would still be prompted that the battery is not charging, the last option before getting a new battery is to reinstall the Operating system. Sometimes, the problem that you are having is also a result of a failing power driver in the Operating system.
The easiest way to check is to put a known good working battery of the same model into your computer to check if its really the battery that you are having problems. If other batteries work, you should replace the battery that you have immediately. If it doesnt, its the laptops charging port that is having problems. If the laptop is still under warranty, you can have it brought to the service depot for repairs by calling DELL. but try doing the solutions that I have mentioned before doing so.
Hope this helps.
Jul 14, 2010 | Dell Studio 1535 Notebook
Charging problems
Hopefully the battery is just confused and needs to be reset. Drain the battery down until the system shuts off automatically, then take the battery out of the laptop for two minutes and plug it back in, and connect the AC adapter, let it charge without turning the laptop on, then turn it on and hopefully it should work fine again. If not then you may need to buy another battery. Try again with another AC adapter just in case because you don't want to replace your battery (expensive!)
Please rate, thanks!
Mar 31, 2009 | HP Pavilion dv6000z Notebook
Green Light turns off when plugged in to the computer.
hi bro what u need to do is ... understand when u plug in the ac adapter the light on the ac adapter goes off and whne u unhoook it it comes on .. right there is a possible static charge in the mobo bcoz of which the ac current is nt able to flo on thru the wires to the motherboard .. what u can do is turn ur laptop off completely unhook the ac adpter and take off the battery as well press the power button for 15 sec press and hold it do this xcersice .. hook every thing up and try to charge the battery again it should work .....second possible thing can be may be the connectors on the mobo can be bad on the pin in the prong on the ac adpter must be twisted ,,, so check for that as well ...if still no go then either problem with the onboard power connector on mother board or the whole mother board power aseembly IE replace the mobo ....
Mar 13, 2009 | Dell Inspiron 6000 Notebook
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 04, 2008 | Computers & Internet
Turning on problems
plug ac in...turn on pc...wait for boot then press and hold power switch(on pc)down until you hear shut down .restart.
if no luck remove battery and do the same precedure(without battery )
if/when pc startup and is in windows replace battery anytime.
Apr 10, 2008 | Toshiba Satellite A25-S207 Notebook
Is the power source a 15v 5a or a 15v 8A? You more than likely have a Dead system board. The blinking amber AC power led usually means a power failure due to improper voltage or amperage.
More than likely caused by a 3rd party (non-Toshiba) adapter.
Sorry for the bad news. :(
Laptop is not turning on
take the battery out and turn it on with only the ac adaptor, then put the battery back in.
Mar 24, 2008 | Toshiba Satellite A45-S151 Notebook
Toshiba Satellite A25-S207 Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
