Question about Gateway ML6731 PC Notebook
Gateway ml6731 black screen
Gateway ml6731 notebook - screen and does not work and will not work on an external monitor. Is this a notebook screen, ccfl voltage inverter or main board problem?
    Scholar:
  • 96 Answers
It is possible that it is the main board or motherboard that is having problems. it is possible that the video card is having troubles.
Posted on Jun 05, 2010
Black screen
Test it with an external monitor. If it does not work with an external monitor, then your motherboard is defective. If your laptop works good with an external monitor, then your screen need to be replaced.
Mar 05, 2014 | Gateway NV53A24u Laptop
THE MONITOR ON MY ONE PIECE GATEWAY PC IS BLACK BUT THERE IS POWER TO THE COMPUTER. TRIED PLUGGING IN AN EXTERNAL MONITOR BUT HOW DO I GET IT TO WORK WITH THE COMPUTER?
Addressing this as a Gateway 4540GZ PC Notebook. If it is a different computer please state in a Comment.
Gateway Support > Gateway 4540GZ main support page,
http://support.gateway.com/s/Mobile/Gateway/4536GZ/4356nv.shtml
User Guides > Click on > 8510221-Gateway Notebook User Guide
Page 31 - System Key Combinations
Press the Fn key, and the F4 key to toggle over to an external monitor.
(External monitor plugged into the VGA port on the back of the laptop, and turned on,
VGA port,
http://en.wikipedia.org/wiki/VGA_connector
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
Nov 02, 2010 | Gateway 4540GZ Notebook
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
My laptop doesn't boot up. Only get a black screen.
have you tried connecting to an external monitor?
Oct 15, 2009 | Gateway M285-E Notebook
Screen on my laptop will not work. Black screen.
Test if it works on external monitor. If it does, then turn the computer on, remove the battery, then reinsert the battery. That little trick has worked several times for me and my customers. If the external monitor does NOT work, then you probably have a bad video chip in the computer's motherboard.... by the time you fix it, you could almost by a new machine.
May 25, 2009 | Gateway M305CRV Notebook
Black screen after returning from florida
plug in > if charge light comes on and screen black proceed.... if no charge light comes on on laptop your charger's not working
plug into external monitor > if the external monitor works fine with laptop then your LCD is not working, you can look for the Function key (should be bottom left) and the monitor button (probably f7) and switch back and forth... this should tell you if the lcd works or not.
Apr 20, 2009 | Gateway MX6027 PC Notebook
Black screen
When i connect an external monitor and use Fn+F3 i was able to see the computer so i guess either the backlight or the inverter is not functional
Sep 22, 2008 | Gateway M305CRV Notebook
MX 6124 Gateway notebook screen stays black when powering up
Repaired! This sounde like a fuelty screen or screen inverter. To check this, connect to an external monitor, if the external works properly, then it's the screen or inverter. If the external doesn't work, let me know and we'll run the problem down to a more indepth (internal) trouble shoot.
Jun 28, 2008 | Computers & Internet
Gateway Notebook MX6027 - Dim Screen
Sorry to say the monitor is poked try to use a external monitor because theyre not cheap to replace. These guys are good and most likely tell you the same!!!
Oct 02, 2007 | Gateway MX6920 Notebook
Gateway ML6731 PC Notebook Logo
115 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
