Question about Maytag M7DH65B2A Dehumidifier
The dehumidifiers runs constantly but no water ever comes out.
  • 30 Answers
Check the water inlet solenoid valve if the voltage is present or replace that solenoid
Posted on Jun 05, 2010
I have a delongji DEM 10 dehumidifier and it keeps switching to pause, I have cleaned filter switched off for a while but it still won't come on
follow this steps and fix it. God bless you
Unless you are licensed and qualified professional, do not try to repair a dehumidifier by yourself. If your unit is running constantly yet there is no water in the tank, try lowering the temperature control. If the problem persists, there may be a problem within the refrigeration system. You may need to pull the filter and clean it. Also try wiping off the unit itself. When the water tank is full, the unit will shut off and will not run until the tank is emptied. The dehumidifier shuts off by a safety switch in the back of the unit. If the switch is not working properly, you may try manually pressing the button or slightly bending the switch.
    Motor If the fan motor is damaged or will not work, no cool air will be coming out of the dehumidifier. The unit, however, may still run. You may need to replace the motor. If the coils in the back of the dehumidifier constantly freeze, try turning off the unit for an hour or re-locating the unit to a higher position to allow the room to heat up. If your water tank is constantly full and you are emptying it on a daily basis, you may have a water leak somewhere in the room with the dehumidifier.
    Oct 30, 2013 | DeLonghi DE500P Dehumidifier
    The unit will not come on. tank is empty. could the sensors be messed up, i turned it down all the way to 35% but it will not kick in yet my other one runs constant. Is there a reset factory button...
    There are many reasons why a dehumidifier willnot work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
    Dehumidifier is running but no water is in bucket
    heatman101
    Jul 16, 2011 | Maytag Dehumidifiers
    Shuts on and off constantly
    heatman101
    Jun 01, 2011 | Kenmore 54501 Dehumidifier
    Dehumidifier is less than a year old. runs constantly but isnt collceting water. air filter was very dirty. cleaned it. now waiting to see if thats it or the unit is bad
    heatman101
    May 11, 2011 | Haier 45-Pint Dehumidifier
    P1 constantly goes on throughout the day. I do not know if I have the setting right or if the drain hose is connected properly.
    First, the drain hose should not be longer than 5 feet and should be draining downward, with no kings or bends in the hose, The dehumidifier does not have a pump. It relies on gravity to drain the water.
    As far as it running all day is concerned, some dehumidifiers have a "Constant" or "Continual" setting. Which means it runs constantly. Either while dehumidifying or defrosting. In addition, most Danby dehumidifier models are designed to have the fan run even when the compressor is not running. This is in order to circulate the air in the room and make the unit work more efficiently. This is a standard feature and cannot be programmed to stop.
    Hope this answered you questions.
    Apr 24, 2011 | Danby DDR4009EE Dehumidifier
    Unit runs constantly, howeverr no water is accumulating in the buckt
    There can be many reasons why a dehumidifier willnot work or collect water.
    http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
    heatman101
    Sep 16, 2010 | Whirlpool Dehumidifiers
    Dehumidifier runs constant.
    There are many reasons why a dehumidifier will not work or collect water.
    Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
    heatman101
    Sep 05, 2010 | Whirlpool AD40USL Dehumidifier
    Why does the dehumidifier seems to run constant without collecting any water?
    heatman101
    Aug 25, 2010 | Fedders A7DH45B2A Dehumidifier
    Unit runs but doesn't pull humidity out of room, filter clean
    Possibly lost refrigerant from system- check warm air is coming out of machine. Otherwise it could be dirty filters, and not getting enough air over evaporating coil. Other than this, replacing parts is usually more expensive than buying a new dehumidifier :(
    Jul 18, 2009 | Dehumidifiers
    Dehumidifier running but not producing water
    Sounds like your relay switch isn't connecting....
    Apr 29, 2009 | Maytag M7DH65B2A Dehumidifier
    Maytag M7DH65B2A Dehumidifier Logo
    307 people viewed this question
    Top Maytag Dehumidifiers Experts
    Michael Van Der...
    Michael Van Der...
    Bill Long
    Mike Squire
    Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
