Question about Kenwood KW85 Air Conditioner
Water poring out, carpet is now a lake, cant find where pan to empty is ...please help
  • 8,197 Answers
On page 11 of link below will tell you how to empty water tank. that is if you have the Kenwood KW85
http://www.sylvane.com/images/productpages/DeLonghi/Air-Conditioners/kw85/KW85.pdf
Good Luck end please rate
Posted on Jun 05, 2010
Testimonial: "thank you, but it is a whirlpool, portable AC ( i posted in the wrong spot )"
  • Jyackle5
    Jyackle5 Jun 05, 2010
    Do you have the model # so I may help you.
After one year of usage my portable A/C drains on the floor approximately 3pint / hr. Unit was raised so that the water can drain into a container without weting the carpet . This situation needs to be...
This is what the manual says:
When the internal water container is full, the back light on the LCD display flashes. The unit will shut off automatically, beep 15 times, and must be drained before it will restart.
To Drain the Unit: switch off the unit and remove the plug from the wall socket.
• DO NOT MOVE THE UNIT. Doing this can result in water
leakage, damaging your floor or carpet.
• Place the drain pan on the floor under the drain cap.
• Remove the drain cap and the rubber stopper from the
drain, and let the water run out. Partially fill the drain pan,
replace the rubber stopper, and empty the drain pan.
This procedure must be repeated until the unit is empty.
• Replace the rubber stopper and drain cap.
Put plug into the wall socket, and switch the unit on.
The warning signal should be off.
For Continuous Drainage: • Switch off the unit and remove the plug from the electrical outlet.
• Remove the Drain Cap and Rubber Stopper. Drain if necessary.
• Connect a Drain Tube (not included) (20mm / 3/4" inner dimension) on to the water outlet.
• Place the other end in a drain. Make sure the tube is free from twists and bends.
The tube must decline over its entire length.
Jun 06, 2011 | Amcor PLM12000E Portable Air Conditioner
Water in carperting
this might sound stupid but is it pitched so that it drains outside instead of level or in towards the house?
May 17, 2010 | Whirlpool AD25BBR 25 Pint Per Day...
Sharp CV-P10NC AC unit it has a puddle of water coming down.
earlier models had a pan you had to empty .. your model has a small pump that is supposed to pump the water out the hot air vent (that goes thru the window} .. since its leaking it is likely that the pump inlet is clogged ... you might have to remove a panel to get at that ... it will be near the bottom of the unit (near the drainage nozzle) ... also check the hose that goes out thru the outside vent .. make sure its not cracked, clogged or smashed ... temporarily you can use the drain nozzle to drain off the water to a lower area (it cant drain up without the pump) ...
Aug 17, 2009 | Sharp CV-P09FX Air Conditioner
Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Not Sucking the dirty water
It seems that when you emptied the recovery tank it has not been placed back proper.
please make sure it is sealed else you will loose suction
Jul 12, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Cleaner was working fine. Emptied the recovery
yes please help0. my carpet is soaked and the machine will not **** up the water
Jul 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Puddles of water are on the floor from the bottom of the refrigerator opposite side of the ice maker (near the compressor or the condenser fan)
Your defrost drain is either blocked, missing the defrost pan, pan cracked or poring through the body of refrigerator. It also could be a leak at your dual water control valve. Let me know what the model number is for example 213.54698 and I will be able to get a picture of your refrigerator and help you better, Thanks, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Jun 18, 2009 | Kenmore Refrigerators
Water pan inder freezer is full & leaking water
it may be that your defrost drain hole is blocked at the back. check it out but runnin a flexi band down it. if its the freezer drain hole you will need to do a full defrost to unblock ice.
Mar 16, 2009 | Refrigerators
Refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Sep 11, 2008 | Refrigerators
Kenwood KW85 Air Conditioner Logo
271 people viewed this question
Top Kenwood Heating & Cooling Experts
ray gallant
Electro Med Services...
Are you a Kenwood Heating and Cooling Expert? Answer questions, earn points and help others
