Question about Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Grill element not working on rangemaster 110
  • 909 Answers
If grill element not working, switch power off and remove back panel to gain access to wiring. Grill element will be toy element. look for any burnt wire, either blue or brown. Re attach where broken and reassemble. If you have any doubts call a technician. Not to difficult though.
Posted on Jun 05, 2010
Hi, I have a Rangemaster 110 (electric double oven), which has a double grill. Unfortunately one half of the grill has blown - not working. Is it easy to repair? Thanks a lot - Krisztina
Usually fairly straight forward. Remove the blown element being careful not to loose the wires into the void behind the grill. Insert new element making sure the orientation and wires are conected as the original was.
Dec 28, 2010 | Rangemaster Range Cookers Kitchener 110...
What do I look for? Rangemaster Kitchener 110
Problem solved, took the back off the inside of oven and the element had a huge burn hole in it. Brought a new element from the local spares shop £17+vat. Easy to fit and it works better than ever.
Nov 13, 2009 | Rangemaster Kitchener 110 Electric Range
The convection oven of my 110 electric cooker is not coming to temperature, the element goes red eventually when on the grill symbol.
conventional cooking uses the outer/grill element plus there is one under the base of the liner to radiate heat upwards... if the top element is heating then the lower element is faulty thats why it never gets to temperature...
Nov 04, 2009 | Rangemaster Classic 110 Kitchen Range
Hi - I have a creda solarplus cooker (48349) - I wish to replace the 8 bar grill element with a 4 bar grill element - can you please advise me of the steps necessary to do same - yours michael clancy
It’s basically as simple as:
Turn off the gas supply to the range.
Turning off the mains power to the range.
Remove the back panel behind the grill.
Remove the 2 power connectors to the grill element.
Remove the earthing wire to the element screw terminal.
Unscrew the grill element securing screws(s) - there will be 1 or 2 depending on the element fitted to your range.
Refit the new element (make sure it has the same mounting screw holes as the one you want to remove) then secure it.
Reconnect the earthing wire to the element screw post.
Make sure that neither of the element tags touch the chassis - check with a continuity tester of ohm meter and adjust if required.
Reconnect the power cables to the element.
Reconnect the power and check that the element works correctly.
Disconnect the mains power again and replace the rear panel(s).
Reconnect the mains power and recheck that the grill functions correctly.
Turn on the gas supply.
Oct 05, 2009 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Grill Element Blown Rangemaster Classic 110
I have the same problem. The installation and service guide details how to change the grill element but does anyone know what the part number is for the grill element?
Apr 01, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster gas grill - little or no gas pressure
you can phone rangemaster helpline on 08707 895 107 spare parts or tech team.
Feb 26, 2009 | Rangemaster 110 (Gas) Kitchen Range
Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Dec 15, 2007 | Kitchen Ranges
Rangemaster 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
942 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
