Question about Black & Decker Garden
While using my B&D PW 1600 power washer, the unit started to cut in and out. I thought that it might have overheated, but it had not been running 20 minutes. After letting it sit for 10 minutes to cool, the pump will not run. It has now sat for over an hour, unplugged and still will not run. Any suggestions? Tony mcss350@aol.com
  • 10,319 Answers
A valve where to hoses are connected to maybe plugged up Here is a video on how to repair it without spending a dime
The video is for a different brand although all have the same valve to make these pressure washers to operate
http://www.youtube.com/watch?v=cUbXxECvtNM
Posted on Jun 05, 2010
My cellphone have a security code what is the code of nokia 1600?
If you dont want to risk your phone use unokia.com ( 9 € ) where all codes are supervised and verified by our qualified technical team. Remember that if you try more than 3 times your phones will be hardlocked and will be not possible to unlock remotely by code.
CODES:
#pw+394976522221470+1#
#pw+045503670357104+2#
#pw+812341440005242+3#
#pw+738950167621352+4#
#pw+114034447232531+5#
#pw+297245322554144+6#
Jun 24, 2011 | Nokia 1600 Cellular Phone
I need to download a Black & Decker manual for a power washer- PW 1600
This link may provide the help you need, There is a phone # that you can call on this site:
www.ereplacementparts.com/black-and-decker-pw1600-1600-psi-pressure-washer-parts-c-4167_9499_9560.htm
I wasn't able to find it.They may know where to link you to to get a download of your manual. I wasn't able to find it.
Jim
Sep 23, 2010 | Garden
Where is the pressure switch located on a simoniz 1600 electric power washer?
There is a pressure switch to cut the motor once target pressure is reached. I.e. when the nozzle is closed. It's a black cheap plastic thing, right in front of the pump body. It has a white plastic lever to trip the switch. It was sticking intermittently on mine. the simoniz 1600 is quite a cheap peace of ****, needs fiddling around every time I use it
Sep 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Need to unlock Nokia 1600 Cell from NET10 USA
Model: Nokia (1600 )
IMEI: 010784000801966
Network: 31038000
#pw+430 537 251 742 424+1#
#pw+423 417 347 071 303+2#
#pw+355 576 773 232 662+3#
#pw+094 753 313 144 540+4#
#pw+845 661 265 273 557+5#
#pw+427 087 743 477 575+6#
#pw+388 676 402 573 266+7#
Jan 21, 2009 | Nokia 1600 Cellular Phone
IMEI: 010783005540546
Network: 31038000
#pw+817 031 233 447 221+1#
#pw+334 376 454 130 667+2#
#pw+849 061 267 647 057+3#
#pw+486 617 207 323 103+4#
#pw+850 611 173 773 605+5#
#pw+094 323 611 100 717+6#
#pw+840 361 762 710 255+7#
Try #7 first...
Jan 09, 2009 | Nokia 1600 Cellular Phone
Need help
try this
#pw+716370736423630+1#
#pw+706280026422346+2#
#pw+003353726103217+3#
#pw+743610362156570+4#
#pw+785370403343333+5#
#pw+809471123714730+6#
#pw+913582733145741+7#
Nov 30, 2008 | Nokia 1600 Cellular Phone
Network unlock for nokia1600
#pw+239055750710113+1#
#pw+225095143360153+2#
#pw+933762053107524+3#
#pw+216455234434415+4#
#pw+007463426504321+5#
#pw+352616576056271+6#
#pw+943302660173463+7#
try this
Nov 24, 2008 | Nokia 1600 Cellular Phone
Probvlam with my cambridge audio 640 a cutting out
Check operations manual for indications as you described. Amps MUST have adequate ventilation. Make sure unit is not in small, semi- closed space or on top of other warm equipment. Check for speaker impedences match that of amp
May 29, 2008 | Cambridge Audio Azur 640A Amplifier
Plz help!!!
Network code (network which locked the phone):
23430000= T-Mobile-One 2 One;United Kingdom.
IMEI number (15 digits):
011257000056625
Phone model:
Nokia 1600
To enter the code to the phone (switch on without SIM card).
Input the Code in the phone as follows:
Your code's are:
#pw+079513401777712+1#
#pw+228125652623623+2#
#pw+404027137232225+3#
#pw+232515167017411+4#
#pw+087803116530105+5#
#pw+742570373007770+6#
#pw+833851766160357+7#
First code in the end of the string must be added + 1#
Code number 7 in the end of the string must be added + 7#
If you have proper software and You know on which lock, phone
is closed just simply enter proper CODE.
If YOU DONT KNOW – which lock is closed do the following:
1. Enter the first code, if it’s the wrong code – WAIT 30 seconds!!! And then:
2. Enter the code number seven this will open all locks.
How to get ‘p’ ‘w’ ‘+’ signs?
Press
* several times on keyboard of phone...
A message should appear something like "Sim restriction off". That means your phone is now unlocked. Or "Sim restriction on"
!!Warning!!
If the codes don’t work after entering 5 codes You will lock the ‘CODE UNLOCK FUNCTION’ and it will be possible to unlock the phone only by using a cable/device.
"Hard work has a future payoff. Laziness pays off now."
May 11, 2008 | Nokia 1600 Cellular Phone
NS- 1600 amp
You need to use a multimeter to confirm that you have a good ground and sufficient voltage on the B+ and remote wires. I'll assume that you've checked the on-board fuses (if it has them).
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v and the amp does nothing, the amp probably has a blown power supply.
May 03, 2008 | Diesel Audio NS-1600 Car Audio Amplifier
Garden Logo
51 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
