Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Water pan full all over floor how to empty and why it is filling up and how to change filter
  • 4,059 Answers
It's probably filling because your filter does need changing. When the filter becomes stopped up it bypasses into the drain pan on some models. Post your model number and someone can look up your diagrams which show the filter.
Posted on Jun 05, 2010
How to drain and fill transmission fluid in 2012 chevy malibu?
GET NEW GASKET AND FILTER FOR TRANNY ALONG WITH THE FLUID (BEFORE YOU BEGINE)
GET A LARGE FLAT DRAIN PAN.
PUT CAR UP ON 4 JACK STANDS.
place drain pan under tranny pan.
undo tranny pan screws - allow one corner to hang lower than the other corner (to allow fluid to drain) slowly remove them all.
Its messy! empty tranny pan into drain pan. set tranny pan to the side. undo the filter clamp, carefully remove the filter - set into the drain pan, remove the gasket around the tranny body/tranny pan.
Clean tranny block surface with clean cloth. install new filter, install clamp tightly. Clean tranny pan, place gasket onto pan and then reinstall tranny pan. (this only change the fluid in the tranny body and pan) If you wan the fluid out of the torque convertor you have pull the pan under the torque convertor and turn the convertor so you can get at the drain plug. Allow fluid to drain into drain pan. Reinstall drain plug and pan. (you will need a lot of fluid) Check manual for qty. Place car back on to ground/floor. Refill tranny through filler tube. Do not start the engine until oil is at full mark, and when you do start it do not all it to run for than 4 minutes - stop and add more fluid and check full mark again (repeat until no longer sinks below full mark. gently test drive around you block -- come back and check level while engine running. Top up if needed.
Siphon out excess above full mark. Test drive around 3 block,
come back check full mark. Because the torque convertor was emptied it can take a while to get all the air out it.
Jul 19, 2014 | 2012 Chevrolet Malibu
Why is there water on my furnace when the a/c is running?
Condensate normally drains into a pan that either empties into a floor drain by gravity or empties into a pump inlet for discharge outside. The drain pan may be clogged, preventing it from emptying or, more likely, the drain pan is leaking condensate.
Jun 28, 2014 | Heating & Cooling
How to change transmission oil
purchace a new pan gasket and filter . put car on hoist . remove pan bolts use a screw driver pry pan carrfully from trans mission being careful not to bend pan edge [gasket seals there] pour oil from pan into pail with out spilling . wipe floor of any drips so you dont slip . remove filter 2 bolts normaly replace filter make sure o ring if it has one hasnt fallen out . clean and replace pan torque bolts to 28ft lbs . lower car fill with 3 liters oil start, idle ,check level add till full dont over fill dont hurry . let run for a bit look under car foe any leaks this is a basic trans filter oil change for all makes.
Nov 21, 2013 | 2005 Peugeot 407 2.0
My water filter was not clicked in all the way so water leaked and filled up the drip pan under the refrigerator and started leaking out onto my floor before I noticed anything was wrong. I put the water...
Hello Terri,
The pan there is for the defrost water that drains into it durning the defrost cycle,that water eveperates automatically so this water too will evaperate as well may take a bit longer since its more but it will evaperate. Also as you know there is no way to remove that pan,but tomorrow it will be empty anyway
Gene
Aug 08, 2011 | Kenmore Side by Side Refrigerator
My front load washer fills up with water when the door is open and over flows
Hi, Your problem possibly lies with the filter down below. If its visible fine, if not, remove kickplate. Place shallow pan under knob. Turn counterclockwise until water starts to come out. When pan is partially full, retiten and empty pan. Repeat until all water is gone. Remove filter and clean. Hope this helps.
Jan 20, 2011 | Frigidaire Washing Machines
Pan under refrigerator is full with water and over flowing
do u have checked temprature of the frezer,u have to empty pan time to time to prevent overflowing
Dec 28, 2010 | Whirlpool Refrigerators
Occasional water running out the side from under refrigerator
the ukf7003 filter is the correct one for your mod. the leak may be inside the freezer . the drain in back may be iced over and the defrost water is flowing out the door and not the drain/ but do ck the pan under neath and make sure it's nt cracked and is in place . .. place some towles around the base to locate where the water is commong from .. mm
Apr 15, 2010 | Maytag 25.6 cu. ft. Wide-By-Side...
532 sub zero evaporation tray is filling up with a
This is only normal in an environment of high humidity. My question is the condenser fan blowing over the condensate pan and is the air hot enough to evaporate the water that is in the pan? Has covers been removed on the rear of the refrigerator that may cause a different flow of air. Are all covers in there correct place and not missing panels that could change the flow of air over the pan? Let me know, Thanks, Sea Breeze
Aug 26, 2009 | Refrigerators
Drain pan underneath fridge is filling on a daily basis
The system is designed to evaporate that water using the warmth of the compressor.. is your compressor warm ? (the drip tray sits on top of it) I see that model has an Ic e maker... to check that the ice maker refill is not running on too long, switch off the ice maker, by lifting the wire arm that checks the level of the ice in the storage bucket.. leave it turned off for a day or two.. empty the drain pan, and check it again after 24 hours.. but if the ice is already full, the water problem may APPEAR to be resolved already, but will return when the level drops and the ice production begins again.
If it is just condensate, then the drain pan should be able to contain the amount it produces, but 3-days straight, would indicate to me, that is not that... if your water pressure is good, it may be that the ice tray filler solenoid is being held open a fraction too long (maybe a second or so) and as the fridge is new, it will be making lots of ice to fill the container up,... so lots of small overfills.. mounting up to a full drain pan. Under normal use,.. other than parties and festive nights, when you use a lot, the water should evaporate faster than it is produced, but it shouldn't be happening at all.. if it is that, then turn the tap at the back of the fridge to where the cold water dispenser slows down slightly.. that should be enough to prevent it continuing.. IF that's the problem.
Apr 24, 2017 | Frigidaire FSC23F7D Side by Side...
Kenmore side-by-side 106.52764100 Frig leaking water
Do you have a Dog ??? I had a customer who had a problem like this once.................Only to find out in the middle of the night the dog jumped up and with his nose pressed the water dispenser..If not plz check inside the freezer and see if your drain is clogged pull the bottom drawer out and look on the back wall..
PS: the pan even with a clear drain will not fill up the condenser fan with the heat from the condenser will evaparate the water after a defrost cycle
Feb 23, 2008 | Refrigerators
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
113 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
