Question about Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome...
Handle won't stay up
Replaced cartridge on moen kitchen faucet to stop leak, but now handle will not stay up on its own. What should I do? Thanks.
I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
Posted on Jul 22, 2010
2 Suggested Answers
  • 94 Answers
SOURCE: Replace cartridge in Moen kitchen faucet and now
it probably has a plastic cartridge,remove it, and push the center piece out slowly and firmly. wipe this down,not completly this is what carries the wieght of the handle.give this a shot.
Posted on Apr 27, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Replaced moen teo handle cartridge 1224 now faucet
    the lines the cartage attaches to will have seals or teflon tap. if the seal has a small nick, it will leak. Or if the tape was applied in the incorrect dircection or was cut it could also creat a leak
    Jul 19, 2010 | Moen & Replacement Cartridge
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Jan 12, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
    turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
    Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
    Moen kitchen faucet model 7430 leak
    cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
    Oct 17, 2009 | Moen 87530 Touch Control Single Handle...
    Moen kitchen faucet. I changed the cartridge but
    Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
    Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
    Moen Single Handle Shower Faucet leak...
    the cartridge if defective,replace it and your leak will stop.
    Jul 22, 2009 | Moen & One Handle Tub & Shower Faucet
    Moen One-Handle Kitchen Faucet Leak - Hot Only
    http://www.moen.com/browsecatalog/catalog/specpartsearch.cfm?location=TopNavCustomerSupport
    Moen uses a cartridge on their faucets. You have to remove the handle. You will find the stem and a small U shaped retainer. Pull the retainer out and pull the cargridge straight up. Sometimes the cartridge is in there pretty tight and you have to pull hard. Once you do this, take the cartridge to your local hardware store. Replace it with the one you have because they have 2 different one. Install it back in the same order it was removed. Hope this helps and good luck.
    Apr 10, 2009 | Plumbing
    Moen 7065 leaking at base of lever control in kitchen faucet
    Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Moen 7840 Camerist Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
    3,262 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
