Question about GE Profile PDS20SFS Bottom Freezer Refrigerator
GE PDS20MCP - the Ice maker is not making ice. Took out full tray of ice and has not made any since? Is there some reset button or something?
  • Gene Strote Jun 05, 2010
    Check the things first. Temperature in freezer. Most ice makers have a thermistat in them and it has to get around 6 degrees or colder in the freezer. Next check the water lines doing to ice maker including the spout that that leads into the icemaker. Also check to see if inlet valve is working.
    Scholar:
  • 44 Answers
Before you the Water Valver - Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable item goes all the way through. Hook back the water line to the icemaker. You will have ice soon. If still not working, replace the inlet water valve at bottom back of refrig.
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/93259-ice-maker-repair.html#post227249#ixzz0pzmjhvPC
Posted on Jun 05, 2010
I have a GE Profile pfss6pkx. The ice maker has stopped making ice and makes a clicking sound. Do I need a new ice maker or is there something I should try first?
Hello Dave;
My name is Peter. I am a retired field service refrigeration technician.
1.) Press the test button while hold the bottom freeze light switch in. The light switch is in the front top part of the freezer. Observe what happens.
2.) Your ice maker will not work if unless you reach temperature. look in the back of your freezer wall. Is there frost or ice build up?
3.) Do you have ice on the bottom of your freezer section? Then you have a frozen drain, ice built up and can not reach desired temperature.
4.0 You have a non repairable ice maker. Sometime these flex types become jammed with a ice cube in the mold. Check this out.
5.) Your ice maker has a sensor. This may be bad, but I do not think this is the problem.
Get back to me on what you find from the above.
Jan 16, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Why does my ge pss26lg side by side despense water but no ice?
Just because you get water from the dispenser does not mean you should also get ice made in the ice maker. Fact is there are two side to the water control valve. One for the ice maker and the other for the water dispenser. Is there ice remaining inside the ice maker slots? If not then pour water into the tray until full and if after the water freezes it drops the ice into the ice bin this will indicate a defective=> WR57X10032 Water Inlet Valve If nothing happens and the ice maker tray are full of ice this will indicate a defective=> WR30X10093 Ice Maker Assembly The ice maker is cannot be rebuilt on this model. I am here if you have questions, Thank You, John T Appliance 911
May 07, 2014 | GE Refrigerators
Ice maker on GE Profile quit working. Emptied tray of ice and put back in, not producing any ice.
Make sure the "Full" actuator is in the down position. Sometimes when the ice tray is removed, the full actuator flips up to stop ice production.
Hope this helps.
Aug 18, 2009 | GE Refrigerators
No Water to Ice Dispenser
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker. Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Jul 23, 2009 | GE Refrigerators
Ice maker auger not turning
ICE MAKER NOT MAKING ICE ON MY GE SIDE BY SIDE FRIDGE.
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker stuck
Switch the ice maker off then back on should reset it . It is possible that the 'ice mould heater' is not working so the ice cubes don't realease from the mould , jamming the motor. Replacement ice maker is usually the solution
Aug 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
The ice maker usually is an easily removable assembly, lift and pull or something like that. It may be the little water line has cracked, plastic don't like being cold.
Jan 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER
See the following fixya thread:
http://www.fixya.com/support/t127529-water_ice_dispenser_not_working
Dec 14, 2007 | GE GSS25JEMWW Side by Side
GE Profile PDS20SFS Bottom Freezer Refrigerator Logo
148 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
