My labtp has been infected bu MonaRonaDona virusM,I managed to removed but the devicese manager items disappeared totally and hence the TCP/IP transport which make difficult to connect to my broad band serices, as result also I lost the help and support functionality due the unrunning services
    Genius:
  • 1,226 Answers
In that case, i suggest you to remove the hard drive and connect it to other computer which has a potent antivirus and scan. You can use the online scan here: http://www.precisesecurity.com/antivirus/online-scan.htm
But most likely if the system is infected with virus, virus can be deleted but the system is slower ..guess reformatting and and windows installation is the best way.
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
best regards, melnavz
Posted on Apr 10, 2008
I have a surface tablet unable to connect to wi fi
Solution 1 - Reset TCP/IP stack
To reset your TCP/IP stack, do the following:
  1. Right-click on the Start Menu button and open Command Prompt (Admin)
  2. Type the following command and press Enter: netsh int ip reset
  3. Reboot your PC and check if you're able to connect to WiFi network. If you can, you're good to go, but if not, type the following commands in the elevated Command Prompt and press Enter after each one:
  • netsh int tcp set heuristics disabled
  • netsh int tcp set global autotuninglevel=disabled
  • netsh int tcp set global rss=enabled
  • ipconfig /flushdns
Solution 2 - Re-configure WiFi Adapter
Maybe reconfiguring your WiFI adapter will solve the problem. To do so, follow next steps:
  1. Go to Search, type device manager and open Device Manager
  2. Right-click on your wireless adapter and go to Properties
  3. Go to Power Management tab, uncheck Allow the computer to turn off this device to save power and click OK
  4. Modify the default power plan, and switch it from high energy savings to low
Jun 30, 2014 | HP Compaq nc6000 Notebook
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Can't find scanner
Is the scanner visible in Device Manager? If not you have a hardware or connection issue.
Is the connection USB or network? If network have you checked TCP/IP settings? If USB are the USB items OK in Device manager?
Is it an old scanner connected to a new Windows version such as Win7. Some old scanners are not compatible.
Jan 11, 2014 | Microtek ScanMaker 9800XL Flatbed Scanner
Don't have permission to access on this server
Sounds like you are going to a site that you are not supposed to be on. Maybe some settings are off and taking you there.
Let's start with Internet Options. If you have Windows XP Click Start/Control Panel/Internet Options. If you have Windows Vista or Windows 7 click Start/Control Panel/Network and Internet/Internet Options.
When the Internet Options window opens on the General Tab make sure you have a valid web address as the Home Page. If not, create a simple Home Page by typing: http://www.google.com You don't have to click OK now because if you do the Internet Options window will close.
Click the Security Tab and under where it says "select a zone to view or change settings" Click on the one that says Internet, then scroll down to near the bottom right and make sure that DEFAULT is grayed out (whereas you cannot click on it). You can Click on Default just to be sure. Next click the Intranet so that it is highlighted and make sure DEFAULT is grayed out so that you cannot click on it. Do the same thing for the other two zones (Trusted Sites and Restricted Sites). After all zones under the Security Tab are set to Default click the next Tab which is the Privacy tab.
On the Privacy Tab you want to make sure that DEFAULT is grayed out, if not click on it. When in doubt just click the Default tab.
Next skip over the Content tab and proceed to click the Connections Tab. On the Connections Tab make sure that the Never Dial A Connection is checked if you have something in the white box above it in for Dialup and Virtual Private Networks settings. Look down on the right near the bottom and Click the LAN SETTINGS button. When Lan Settings open up the only box that should be checked is the very first box that says: Automatically Detect Settings. If any other box is checked remove the check from it or you will never be able to connect. Click OK to close the LAN SETTINGS tab.
Next skip over the Programs tab and click the Advanced tab. When it opens slide the blue bar on the right all the way down until you get to the bottom of the window. You want to be able to make sure that if you see something like (Use SSL 2.0, Use SSL 3.0, Use TSL 1.0) that you put a check in the box to the left of each one of them. Afterwards you can click OK to close the Internet Options Window.
Next lets go boot your computer in Safe Mode.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download and nstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the Gui Interface will open up with an offer to Accept a Trial Version o Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
Check your Network Settings for TCP/IP (you might have TCP/IPv4 and TCPIP/V6 if so check both of them).
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Networking tab. Find the Protocol (TCP/IP) in the drop down window that says "This Connection Uses The Following Items" and Double Click on it to open it. You should make sure that you select Obtain IP Address Automatically and Obtain DNS Server Address Automatically. Click OK.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Network Connections. Right Click on the Wireless Network then select Properties. Find the Protocol (TCP/IPv4, TCP/IPv6) in the drop down window that says "This Connection Uses The Following Items" and Double Click on it to open it. You should make sure that you select Obtain IP Address Automatically and Obtain DNS Server Address Automatically. Click OK.
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Network Connections. Right Click on the Wireless Network then select Properties. Find the Protocol (TCP/IPv4, TCP/IPv6) in the drop down window that says "This Connection Uses The Following Items" and Double Click on it to open it. You should make sure that you select Obtain IP Address Automatically and Obtain DNS Server Address Automatically. Click OK.
May 08, 2012 | Microsoft Internet Explorer 9
Connect two tigerswitch 6724AL2 via fiber port
How do I open ports in the Virtual Server? pix.gif pix.gif pix.gif You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows.
  1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter.
  2. Click on Login, Advanced Setup, NAT, Virtual Server.
  3. Enter the port details and enable it as follows:
Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx To access the application, you can open up the ports specific to the application in the special application, which is present in the router management screen as follows:
  2. Click on Login, Advanced Setup, NAT, Special Application.
Trigger Port Trigger Type Public Port Public Type Enabled 3724 TCP 3724 TCP Y 6112 TCP 6112 TCP Y 6881 TCP 6881-6999 TCP Y
* The port numbers given are just an example. You need to open the ports depending on the application you are using and should get the information from the application provider.
Jan 05, 2011 | SMC TigerSwitch SMC8612T
Why does the facebook could not be open?
This problem can occur if there is a mismatch between the configured IP addresses in the Advanced IP Addressing dialog box and those listed in the Server Properties dialog box for the DNS server. This problem can also occur if the TCP/IP protocol is not bound to the network adapter.
User Action:
Verify that the TCP/IP addresses configured in the Advanced IP Addressing dialog box match those configured in the Server Properties dialog box in DNS Manager: 1. Open Control Panel, and double-click Network. 2. Click the Protocols tab, and click TCP/IP Protocol in the Network Protocols list. 3. Click Properties, and click Advanced. Match the IP addresses to those displayed on the Interfaces tab of the Server Properties dialog box in DNS Manager: 1. In DNS Manager, right-click the DNS server name, then click Properties. 2. Click the Interfaces tab, and compare the IP addresses with those from the Advanced IP Addressing dialog box. 3. Repeat steps 1 and 2 for all DNS servers configured in DNS Manager. If there are no IP addresses configured in the Advanced IP Addressing or on the Interfaces tab of the Server Properties dialog box, enter the IP address of your network adapter. Use the ipconfig -all command at the command prompt to obtain your IP address. Check the binding of the TCP/IP protocol to the network adapter: 1. Open Control Panel, and double-click Network. 2. Click the Bindings tab. 3. Verify that the bindings for all protocols to network adapters are enabled, and that no broken connections exist in the stack.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Sep 25, 2010 | Computers & Internet
How do I change the ip address from the lcd display?
hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • Jul 02, 2010 | Zebra Printer 140-751-00000
    Dial up connection ends in error code 720, can't connect to the internet. Using a back-up pc that is terribly slow. would like to fix pc.
    Error 720 - the connection attempt failed because your computer and the remote computer could not agree on PPP control protocol.
    To resolve this issue, uninstall the TCP/IP protocol, remove the second WAN Miniport IP device, and then reinstall the TCP/IP protocol. To do so, follow these steps:
    1. Uninstall the TCP/IP protocol. To do so:
      1. In Control Panel, double-click Network and Dial-up Connections, right-click Local Area Connection, and then click Properties.
      2. Under Components checked are used by this connection, click Internet Protocol (TCP/IP), and then click Uninstall.
      3. Follow the on-screen instructions to uninstall TCP/IP.
      4. Restart the computer when prompted, but click No if you are prompted to allow Windows to enable a protocol.
    2. Right-click My Computer, and then click Properties.
    3. Click the Hardware tab, and then click Device Manager.
    4. On the View menu, click Show hidden devices.
    5. Under Network adapters, there should be no WAN Miniport IP devices. If a WAN Miniport IP device is listed, continue to the following step. If no WAN Miniport IP device is listed, go directly to step 16.
    6. Click Start, click Run, type regedit in the Open box, and then click OK.
    1. Locate the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002BE10318}
    2. On the Registry menu, click Export Registry File, type backup-key in the File name box, and then click Save.
      Note You can restore the changes that you make to this registry key. To do so, double-click the backup-key.reg file that you saved.
    3. Click each of the registry subkeys under this key, and then view the Data column of the DriverDesc value to determine which of the subkeys corresponds to WAN Miniport (IP). For example, the 0005 subkey.
    4. Right-click the subkey whose DriverDesc value data is WAN Miniport (IP) (for example, right-click 0005), and then click Delete. Click Yes to confirm that you want to delete the key.
    5. Quit Registry Editor.
    6. Right-click My Computer, and then click Properties.
    7. Click the Hardware tab, and then click Device Manager.
    8. On the View menu, click Show hidden devices.
    9. Under Network adapters, right-click WAN Miniport (IP) and then click Uninstall. Click OK to confirm that you want to remove this device.
    10. Reinstall the TCP/IP protocol. To do so:
      2. Click Install.
      3. In the Select Network Component Type dialog box, click Protocol, and then click Add.
      4. Under Network Protocol, click Internet Protocol (TCP/IP), and then click OK.
      5. When the protocol is installed, click Close.
    11. Reset the modem by turning the power off and then on, or for an internal modem, restart the computer.
    12. Test your Internet connectivity.
    May 02, 2010 | Acer Aspire T650 PC Desktop
    How do I change my I.P. addess...I'm having compatibility problems with my wireless router and cant get on line
    1.
    Control Panel
    Network Connections
    Wireless Connection
    Properties
    Make sure Internet Protocol TCP/IP is set to "Obtain an IP address automatically"
    2.
    Start/Run
    CMD<enter>
    ipconfig /release<enter>
    ipconfig /renew<enter>
    Nov 27, 2009 | Compaq Presario 700 470024-192 Notebook
    Webpages are not being displayed
    It is not a problem with your wireless, it is a problem with your Windows installation. Here are two things to try...
    1. Run some sort of registry repair program. - Glary Utilities is a good free one, CCleaner is free and does reg stuff.
    2. To reinstall TCP/IP, you can Remove your Network Card in the device manager, then reboot your computer. When it reboots, it will redetect the NIC and install the drivers, including the TCP/IP transport protocol. I very recently dealt with this problem, and the registry repairs fixed it.
    Keep me posted...
    Jan 06, 2009 | Dell Inspiron E1505 Notebook
    Computers & Internet Logo
    David Payne
    David Payne
