Question about Roper RES7646KQ Electric Dryer
Dryer wont heat up
Dryer is only 7 yrs old is it the heating element or a thermostat
  • 30 Answers
Check voltage going to the heater,if no voltage check the contactor if energize,if not energize,close the power and check the thermostat with multimeter and test the continuity if the contact will close or open.
Posted on Jun 05, 2010
Dryer heating element comes on sometimes and then shuts off.
Start by checking all the thermostats for continuity.
Nov 05, 2012 | Dryers
Brand new dryer wont heat
depending on which model roper dryer it can be a thermal fuse,high-limit thermostat,cycling switch,burned off wire in control panel,check each side of the heating element to ground and find 125 v.a.c. then on the side of the element that has low or no voltage on it to ground start at the element and back track the components leading to the dead leg on the element till you find 125 vac to ground and replace or repair component or wire,then you should get 240 to 250vac across heating element terminals
Feb 17, 2012 | Roper Dryers
My maytag electric dryer wont heat up
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My dryer is not heating,we have checked all of the settings, and the barrel is spinning so can you please help, the unit is about 4 yrs.old I have a maytag neptune
check ur breaker first, dryers will run on 120volts but wont heat unless have 240.
if electric check ur heating element, thermostats, and thermal fuse for continuity with a meter.
if gas check the ignitor,thermal fuse, and secondary gas coils,
Feb 05, 2010 | Maytag Dryers
No heat from dryer
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Amana ALE331RAW Gas Dryer
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
No heats from the dryer. the mechine is 4 yrs old.
First thing is to check the fuses. Often there is a separate line for the heating elements. If that fuse or circuit breaker is tripped there is no heat but the dryer will still turn.
There are heating elements behind the drum that may need to be replaced if broken. Also check thermostat control.
Sep 16, 2008 | Whirlpool Dryers
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
White westinghouse
I have the same AEG T57800 dryer.  Problem, no heat. Couldn't find a service manual anywhere on the net. Checked for fuses and saw none. Thermostats on heater appeared fine, showing current flow. Replaced heating element 112 54 84 41/8, via local dealer - Respond Services from Electrolux UK in Durham DL5 6ED (£68), still no heat.  Called service tech who replaced the PCB - 973916012018008 (£135 + £85 callout charge). Very, Very annoyed at this as the dryer is only 3.5 yrs old.
Dec 11, 2007 | Dryers
Roper RES7646KQ Electric Dryer Logo
54 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
