Question about Car Audio & Video
Yes i order an antenna adapter for a 2005 dodge dakota.. The end that goes into the radio fits perfectly but the end that attaches to the antenna itself will not fit.. the antenna has a round black plastic piece on it.. any solutions?
  • 2,272 Answers
The adapter is not exactly the same which is required.but yes you can get the external connection for adapter which will fit in adapter and also get connected to the antenna.You will have to get this external connection from
www.walmart.com or from
www.radioshack.com
check out.thanks.
Posted on Jun 05, 2010
Can you tell me the antenna stud size for a Dakota Alert M-538 HT MURS radio?
It's called a reverse SMA. You can get a reverse SMA (f) to BNC (m) adapter for $5 and put any MURS antenna on it you wish. Here is a link to where I get mine at. Reliable people there. LAN SMA-38-TGN ( SMA female - BNC male ) http://www.associatedradio.com/ about midway down the page under RF adapters.
Mar 18, 2011 | Dakota Alert M538-ht CB Radio
Will this radio work in a 2005 Ford Focus hatchback
Yes but you will need a Quadlock to ISO harness adaptor and antenna adaptor and facia adaptor, roughly £30 of parts.
Nov 20, 2009 | Pioneer DEH-P5800MP CD Player
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Procedures to install cb antennae mount
The end without a connector was once attached to an antenna. You need a proper antenna in order to use the radio. If you were to buy a new antenna, it will come with a length of cable attached. Even if you were to buy a new antenna, don't expect good performance from the radio unless you get the antenna properly adjusted. Yes, it will work "out of the box", but probably not as good as it could. There is a device called an SWR bridge, it's used to measure the SWR and the user then adjusts the antenna for the lowest reading by trial and error adjustment of the antenna.
Jan 23, 2009 | Cobra 18 WX ST II 40-Channels Base CB...
GE spacesaver 05GP009
I had this same problem, I wanted to use this tv with a converter box and the only way to do this was to hook up the converter box with an external antenna to the small 3.5mm input on the back. If you go to radio Shack and get an "F to 1/8" Adapter"the radio shack part number is "278-257". It worked perfectly. I'm able to get many clear channels, and with the converter box I now have remote control. It works well. Good luck, I hope this helps
Mar 02, 2008 | GE SpaceMaker 05GP009 Television
Antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Aug 15, 2007 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
