Question about Garmin Forerunner 305 GPS Receiver
My Garmin Forerunner 305 doesn't go on when press the power button. It is fully charged. I can get it to activate pressing mode and lap/rest at the same time usually after several attempts. When the unit is on the light function works and I can turn it off using the power key. I should also mention the unit worked fine two days ago. Is there an easy adjust I can make to allevate the problem?
  • 1,170 Answers
You need a new battery. There is a small chance there is a hardware problem but about 99.9% of the time its just the battery giving up.
Posted on Jun 05, 2010
It does not turn or or charge. Connected to laptop but got same results. Tried to install latest software but it would not the unit (forerunner 305). Message was that there was no unit connected...
Here's a few options: Soft Rest
- Hold down MODE + RESET for few seconds
- Press the Power button to turn on the device
Hard Reset
(This will erase all of your data inside the device)
- Hold down MODE + RESET + POWER for few seconds
Firmware Downgrade/Upgrade (2.9 > 2.8 > 2.9)
(This will erase all your data inside the device)
Software Downgrade/Upgrade
- Connect your Garmin Forerunner 305 to the computer
- Press the UP arrow button and hold while doing all the other steps below
- Press MODE + RESET for a moment (the computer will recognize the device)
- Dowload the Firmware from Garmin's website.
- Downgrade Firmware from 2.90 to 2.80. (You are still holding on that UP arrow button!)
- When the update is finished the Forerunner 305 should power on running the Firmware 2.80.
- Let go of the UP arrow button, disconnect the device from USB, connect it again and the computer should recognize it normally
- Update the Firmware to the current version.
Nov 04, 2012 | Garmin Forerunner 305 GPS Receiver
My garmin forerunner 305 turns off automaticly after a couple of minutes, and the battery is fully charge.
Try SW reset. Hold Mode and lap/reset for 10 seconds, then release and long press start until device restarts.
Should clean up default.
If not try hard reset, but you'll loose all data in device.
hold mode and start for ten second, device needs to off before.
Then keeping these, pulse press lap/reset.
You'll get a confirmation screen
Oct 04, 2010 | Garmin Forerunner 305 GPS Receiver
My Garmin Forerunner 305 quit working at mile 15-ish during my 26.2-mile journey. There was a faint sound but the screen was blank. It doesn't seem to charge. I tried soft reboot by pressing on the MODE...
Try hard reset.
Hold mode + start for ten seconds (device off beforehand). Keep holding then pulse push lap/reset button.
You get a screen asking to return to default settings. You will loose all your data, but device should work then
Sep 26, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin 305 would not turn on after a ride. would
Reset your unit by pressing the "Mode"(reset/lap) and "Power" buttons at the same time. afte it turns on run system updater on computer
Jan 10, 2010 | Garmin Forerunner 305 GPS Receiver
Ive not had my garmin 305 long, it will not charge or turn on.
This might just need a reset. To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version available by downloading and running the WebUpdater program. To update the software, please use the following link:
http://www.garmin.com/products/webupdater/
Sep 21, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin forerunner 305 won't turn off and keeps ringing .
You can reset the unit by pressing the and holding the mode and lap buttons simultaneously. This will power it off.
Jul 24, 2009 | Garmin Forerunner 305 GPS Receiver
My Garmin 305 is not working. IT will not power on.
I've had the same problem for a few months. Only workaround is to press the lap and mode buttons together and then press the on button. Should come on in about 5 seconds.
Now can't launch training centre and no maps shown in garmin connect.
Jul 11, 2009 | Garmin Forerunner 305 GPS Receiver
My garmin 305
Press and hold the mode and lap buttons for 10 seconds, then release. Most of the time, that will fix it. Garmin has a sort of sleep mode programmed in for certain situations. If that doesn't work, I have had wonderful success with Garmin tech support.
May 16, 2009 | Heartbeat Garmin Forerunner 305 Gps...
Garmin Foreruner 305 will not turn on or charge
I had the exact same problem and thought my beloved forerunner 305 had finally died. Try pressing the lap and mode keys simultaneously, and then power on. That may do a "soft reset." Worked for me.
Jan 05, 2009 | Garmin Forerunner 301
NO life in my Forerunner 305
There is a hidden recessed button on the right side of the Garmin. Press this button and it should reset the unit and it should turn on immediately.
Jan 13, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
932 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
