Question about Hitachi 61SWX10B 61" Rear Projection Television
When I turn the power on it turn right back off
  • tina conklin Jun 05, 2010
    when i turn the tv on it turn off right away nothing even comes up on the screen the power light comes on then goes off
  • tina conklin Jun 06, 2010
    I dont know if it was helpful we will see he wanted model # so he could get me the right part if it works that is the only way i know if it help ful.
  • 6,784 Answers
Hi. This will usually be the result of one or more failing components that are mounted on the power board(replacing the power board will correct this issue). I will need the entire model number of this particular unit, if possible. This will allow me to look up the necessary part number needed and chassis schematics, as well.
Please post the model number, asap..
Posted on Jun 05, 2010
    Model #61SWX10B Serial # V2C007987
  • Michael Masters
    Michael Masters Jun 06, 2010
    Hi again. Ok, i have located the necessary part number needed. The part number for your new replacement power board will be JT22046R. Click on the part number to purchase.
  • Hitachi Master
  • 11,800 Answers
The power sources enters in protected mode when it detects a fault. Judging by how fast the shutdown is my guess is that the problem is on the high tension line.
The only way to find out precisely what the fault is and where is to open the tv and check the voltages. If you're gonna see some bulging electrolytic capacitors you will know for sure.
  • Azrael SRL Jun 05, 2010
    As i said this is a major hardware fault, not something related to a bad command or setting. The tv must be opened and tested, no way around that.
I have a Honda Pilot. Several times during the last 6 months, the Pilot loses engine power while making a right turn at speeds from 10 to 40 mph. As soon as the turn is complete the power returns to the...
Maybe a blockage in fuel line, I had this problem with my classic Mini when I turned left it would die when back straightened up everything back to normal.
Mar 11, 2014 | Honda Pilot Cars & Trucks
2004 chev silverado ext cab. No Power steering
Hi Hollings,
You description was very good, I need to ask for a specific.
When you turn to the left, the wheel is stiff like the engine is off or does it turn smoothly but the vehicle doesn't turn or seem to respond.
I'm trying to rule out broken mounts,
Also, if the wheel is all the way to the right, is it difficult turning back to the left the whole way, or half way. See where I'm going.?
Please comment back your findings
Best regards
Mike
Sep 07, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
May 21, 2009 | Sanyo Televison & Video
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Will not turn back on
Take off back cover. The problem power board is to the right of the board where the power plug feeds into the TV. There is a large white fuse right bend the power plug. With a meter it read ok; about 8 inches deeper into the TV on that board was the resister next to two fuses. My 4 amp 125 volt fuse did not read on my meter. After replacing, it worked fine.
Feb 12, 2008 | Pioneer SD-P50A3Q 50" Rear Projection...
Screen shuts off
my screen will turn on right after unit is plugged in and stay on for a short period of time, then it shuts off and the red light near the power button blinks and teh tv will not turn back on. there might be problem of loose contact in power supply Thanks
Sep 11, 2007 | Toshiba 32AFX61 32" TV
Hitachi 61SWX10B 61" Rear Projection Television Logo
64 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
