Question about Minn Kota 55 AutoPilot Universal Sonar Combo GPS Receiver
I have a minn kota copilot that I have used for 4 years. When I went to hook up the battery after the winter this year, I hooked up the positive first and then as soon as I hooked up the ground the motor started to turn. I made sure the remotes were not the cause by taking out their batteries. I cleand the terminals also at the hookup at the motor. As soon as I touch the cable to the battery it starts to turn again. What Is wrong?
SOURCE: Minn Kota tolling motor
Reverse the polarity on the trolling motor by taking the trolling motor apart and turning ithe motor housingt 180 degrees and bolt it back up. The polarity will be straight then. I did the same thing when I pulled the armature back in.
Posted on Jan 09, 2008
SOURCE: mINN kOTA 70 LB THRUST FOOT CONTROLLED TROLLING MOTOR
VONNY MY MOTOR DOES THE SAME THING AND I FOUND THAT THE DUST OF THE MAGNETS IN THE HEAD WAS CAUSING THE MOTOR TO STICK I CLEANED INSIDE WITH ELECTRICAL CLEANER AND IT STARTED TO WORK FINE BUT YOU MAY HAVE SOMETHING ELSE GOING ON AND ALSO MAY SURE YOU ARE NOT COVERED UNDER WARRANTY IF YOU JUST GOT THE BOAT
Posted on Jan 21, 2008
SOURCE: Minn Kota copilot remote settings
Pushing the speed increase and the speed decrease buttons on the remote at the same time sets the audio output mode to one of 3 modes.
Posted on Jul 20, 2008
SOURCE: minn kota turbo 35 27lb thrush trolling motor
I have a minn kota turbo 35 27lb thrush trolling motor after 3 hours of running it the motor dies
Posted on Aug 03, 2008
SOURCE: minn kota 65
IF YOU HAVE CHECKED FOR WATER AND THE MOTOR UNIT IS DRY, DO YOU HEAR CLICKING COMING FROM YOUR MAIN CONTROL BOARD? IF SO THE MAIN BOARD WOULD NEED TO BE REPLACED.
Posted on Aug 07, 2008
My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
How do you program extra Minn Kota® CoPilot Replacement Transmitters? I have lost my instructions. Thanx
According to my user manual
To learn the ID number of additional remotes, follow these steps:
1.) Press and hold the LEARN button located on the side of the receiver (receiver will emit a continuous tone). A small blunt object must be used to depress the LEARN button (pen or screwdriver).
1.) Press any button on the remote (receiver will beep 4 times confirming that it has "learned" the ID number of the remote and that the programming is valid and complete).
Apr 28, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Apr 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Wiring diagram for a minn kota mk220 2 bank charger
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals.
The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
Feb 27, 2009 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
How does the minn kota 65 all terrain run on 24
You should only run the motor with a 24v battery or two 12v batters 'jumped' out. To jump the two batteries, connect the positive on one batter to the negative on the other battery and hook the trolling motor battery cables up to positive and negative terminals that are NOT jumped out as you would normally. Don't run this with 12v as you will have serious problems if you do. They do not make a 65lb thrust in 12v - too much pound thrust to run off of 12v.
Feb 22, 2009 | Minn Kota Endura 30 Freshwater Transom...
Proper batterie hook up on minn kota 70 thursh
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
http://www.mikesreelrepair.com/./index.php
Oct 15, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Jul 19, 2008 | Minn Kota Boating
GPS Logo
145 people viewed this question
Top Minn Kota GPS Experts
Are you a Minn Kota GPS Expert? Answer questions, earn points and help others
