Question about Lexmark Z735 InkJet Printer
Lexmark printer z735
Need info on how to download disk to connect printer to computer my cd rom drive does not work can you help me
    President:
  • 1,944 Answers
You can download here from Lexmark.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?lxkprod=Lexmark+Z735+Color+Jetprinter
Just pick your operating system.
Posted on Apr 10, 2008
Computer is not reading the installation disk
By installation Disk do you mean the CD/DVD-ROM? If yes
Check to see if the drive's LED flashes when the system is trying to boot. If it doesn't, open the system and make sure all the cables to the CD/DVD- ROM is properly connected and to the right slots. If the cables are properly connect and the CD/DVD- ROM is still not working replace the CD/DVD-ROM.
However, if its that the system could not install a particular program, make sure the installation files are complete and try again. If its a downloaded program, verify the completeness of the file downloaded and try reinstalling the program.
Feb 13, 2012 | Peachtree Software Computers & Internet
Everytime i open the computer it reads the feature you are trying to use is on a cd rom or removable disk insert the aiosotwarenpidisk
"AIOsoftwareNPI" is included on the CD that came with your HP All In One printer. Place the HP All In One disk into the optical drive (CD / DVD ROM drive) and restart the computer. "AIOsoftwareNPI" will automatically be installed after boot.
If unable to locate the ****, go to HP's website to download the disk for your particular All In One printer.
I hope this helps. Please rate my reply - thanks!
Jan 03, 2011 | Microsoft Windows XP Professional for PC
I NEED TO INSTALL THIS PRINTER MFC-7420 on my laptop which do not have cd rom player
You have several options to do this:
- If you have spare PC, you may copy the content of the CD to a USB disk and install from the USB disk on the laptop
- Or you may just insert the CD on another computer on the network and share the CD-ROM drive by going to My Computer-Right Click on the CD Drive and click share. Now on your laptop go to My Network Places (usually on Control Panel) where you can see the shared CD drive from your other machine.
- Or if your laptop has internet access, visit Brother website and type your printer model to download the driver installer on your laptop machine.
Good luck and hope this helps.
Nov 03, 2010 | Brother MFC 7420 All-In-One Laser Printer
My pavilion dv5000 says on startup media test failure check cable
Computers can start-up ("boot") from many different devices:
* 3.5" diskette,
* CD-ROM,
* USB memory-stick,
* disk-drive,
* network,
* external USB CD-ROM
and so on.
Your computer is trying to use the network adapter to download a bootable image through a connection with a network-cable to a "network-boot-server" computer.
In your case, "check cable" means that your computer's network-port is either *NOT* connected to a network, or that no "network-boot-server" responded to the request to download to your computer.
First, check the "boot-order", i.e., the priority of each of the bootable devices, to ensure that "boot from network" has a LOWER priority than booting from your diskette, your CD-ROM, and your disk-drive.
Second, check that your disk-drive *IS* one of the bootable devices.
Is there any bootable media in the diskette?
Is there any bootable disk in the CD-ROM?
If not, then your computer has *TRIED* and *FAILED* to boot from your disk-drive, and then tried and failed to boot from the network.
So, it's possible that your disk-drive has failed.
Take the computer to a qualified technician, and get them to remove the disk-drive from your computer, and to connect it to another computer, to see if the disk-drive still is in working-order.
Nov 05, 2009 | HP Pavilion dv5000t Notebook
Sir When i connect cd rom & hard disk together on my computer then the does not work.Kindly give me a solution.
There is a jumper in HDD and CDrom
  • Set the hard disk jumper to Master Connect the drive using the Master connector on the primary IDE cable.
  • Set the CDD jumper to Slave Connect the drive using the Slave connector on the primary IDE cable.
To know about jumper settings verify this link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph03792&lc=en&dlc=en&cc=us&product=3872037
Aug 28, 2009 | Computers & Internet
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
My computer's disk drive does not work how do i install the printer now?
are you refering Disk Drive to CD ROM? if yes then you may need to download drivers for your printer and perform the installation. not sure what is your printer and OS. below link may be helpful to solve your problem.
http://etech.maiila.com
if your hard disk is having problem you may need to repair the HD before able to install the printer...
you may find useful link to solve HD problem here... http://etech.maiila.com
Nov 02, 2008 | Office Equipment & Supplies
Olvietti
The company that made the printer should have a web site, this is one I found that should help http://www.opendrivers.com/company/21438/olivetti-free-driver-download.html3
There are many others if you google it. Just go there, download the driver(program that makes the printer work with your computer) and you should have it. You can also take the file and save it to disk so you have a disk with the driver on it in case you get a new computer.
Nov 01, 2008 | Olivetti (AA6195) Internal 8x CD-ROM Drive
Cd rom has stopped working. the light is flashing as if it is working but the cd is not spinning.
Check the disk for scratches, and try other disks to make sure the problem is not unique to that one disk. If all disks fail, then double-click on My Computer, then double click on the CD-Rom drive and see if a CD will run. The "autorun" option may have been disabled, which is very noticeable if you've been used to this feature working. To re-enable autorun, right click on the cd-rom drive in My Computer, and go to device properties - recheck the autorun or autoplay option.
If none of the above resolve, then turn off your computer. Open up your computer with screwdriver. Unplug and replug the cd-rom driver. Restart computer. Test cd-rom drive again.
If it still fails, Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> DVD/CD Rom Drives - se if the drive has a yellow exclamation by it - if it does, then right click on the yellow exclamation, and click install drivers - windows will most likely find a solution
If all of the above fails, write back with more details, including model/manufatcurer of cd-rom drive, and model/manufatcurer of computer.
Jun 11, 2008 | Computers & Internet
Brother DCP-130C printer
download the whole mfl-pro suite drivers at www.brother.com choose your country and your dcp. After downloading install. You cant run paperport due to the fact that it is part of the cd. But all needed drivers will be installed..
Apr 08, 2008 | Brother DCP 130C All-In-One InkJet Printer
Lexmark Z735 InkJet Printer Logo
66 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
