Question about Danby DWC310BL Wine Cooler
Leaking water from the back
We cannot find our manual for this wine cooler. It started leaking water in the back of the coller. What should we do. At this time we have shut the coller off. How can we optain a new manual. And can you please help us in the mean time. Please respond asap since this cooler is full .
Thank you
    Problem Solver:
  • 14 Answers
Make sure that the drain is connected properly at the back.
Make sure that the little drain pipe (usually clear hose) is sitting in the plastic shroud that sits on top of the compressor at the back of the fridge.
Posted on Apr 10, 2008
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
My wine coller won't hold the temperature set
If it IS a small compact refrigerator, used as a wine cooler, then it may be "iced up" and just need defrosting, if only part of the coil is iced, it is probably low on gas, or the "condenser" coil on the back (or under) the unit may be dirty, a fan not running, or just too close to a wall and not breathing). It is "doubtful that the thermostat is bad, but just setting it colder will tell, and the "setting" is usually marginal anyway.
If it's a larger unit with a fan or fans inside Like a walk-in cooler, then there are other possibilities
May 12, 2011 | Refrigerators
Myy cooler isnt getting cold
there will be a leak in the pressurised line, leak check it with soapy water. if you cant find anything then get it re gassed, hope this helps :)
May 03, 2011 | Emerson (025806803716) Wine Cooler
NEEDED: manual for BC 112G wine cooler
Hello Ahanaples,
I understand that you are trying to locate a user manual for you Haier BC112G wine coller. I have located the manual on Haier.com the following link will take you to the page then you just have to click on the model of the unit that you have the first one at the top of the page.
http://www.haieramerica.com/en/support/modelsearch
Thank you for choosing FixYa.com
Justin Burnett
Mar 28, 2011 | Haier BC112G Wine Cooler
Our kenmore wine cooler started leaking water all over the floor.
I don't know how it is leaking water, it isn't hooked up to a water supply. better start looking for the actual source of the water
Mar 23, 2011 | Kenmore 13485 Wine Cooler
It leaks water from underneath
It is not really leaking water (did you put water inside?) ... that is probably condensate ... a by product of the cooling process. Are you in a high humidity area? If yes ... that is the primary reason for this water.
Here in North America, we think that only white wine should be chilled and then only to 'celler' temp (or about 55 degrees F.
You may be able to reduce the water problem if
(1) up the temp in the cooler (it isn't a refrigerator - don't use it as one)
(2) don't put 'hot' wine inside
(3) put a small fan blowing on the cooler to help evaporate the condensate.
If the water is a big problem, sit your frig on a big tray, similar to the one you might put under your car in the garge to catch dripping oil.
I hope you find these suggestions helpful.
Thanks for visiting and please come again.
Feb 05, 2011 | Haier BC112G Wine Cooler
Water leaking out of the back
HAVE YOU CHECKED THAT THE PIPE TO THE PAN IS IN THE PROPER PLACE.ALSO CHECK IF THERE IS NO ICE ON ANY OF THE PIPES.LET ME NO IF YOU NEED FUTHER ASSISTANCE. GOODLUCK.MOHAMED
Sep 17, 2008 | Danby DWC283BLS Wine Cooler
Danby Wine cooler runs and runs
not hard to replace but you are correct if it is not cycling off at the temp you want it to then the temp control is the problem
Apr 12, 2008 | Danby DWC283BLS Wine Cooler
Water leaking from unit
It may be the drain line is not dripping into the catch bucket under the back side, visually check to see if the line is reaching into the bucket and that it's not clogged up on the inside of the unit floor. The back panel being wet may just be condensation in between cooling cycles as the frost melts. If the unit is OK with keeping temps the refrigerant charge is likely OK.
Nov 21, 2006 | Haier HVF060A Wine Cooler
Danby DWC310BL Wine Cooler Logo
307 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
