Question about Maytag Atlantis MDG7400AW Gas Dryer
Timer starting to go out?
Hi- I have a 5 year old Atlantis dryer. About 6 months ago the regular intellidry cycle wouldn't come on - so I started using permanent press intelli dry or time dry - then the permanent press cycle wouldn't come on - so now I only have time dry - recently (about 2 or 3 weeks ago) the time dry started acting like it was going to stop coming on - I have to pull it down as well as out to start.
Is it the timer that needs replaced? Should I just call the Maytag guy?
    President:
  • 1,554 Answers
The timer is indeed going out and needs replacement. But the good news is you don't have to call a Maytag guy to replace it for you as you can do it on your own. Just make sure you disconnect power to the dryer to avoid getting electrocuted.
Carefully lift the timer knob and dial off the timer shaft by pulling the knob away from the face of the console. Remove the timer dial skirt to expose and remove the timer mounting screws.
Remove the screws securing the console rear cover plate across the rear top edge of the console. Cushion the top cover then grasp the top of the console then rock it forward and roll the console forward. Carefully lift and roll the console forward onto the top cover to access the timer.
Remove the faulty timer and secure it in place on the console. Disconnect the wires one at a time and connect it to the new timer to avoid messing up the wires.
Roll the console back into an upright position and engaging the locking feet into the slots in the top cover and secure the the console back into position. Please indicate the exact model number for accurate replacement procedure and exact replacement part numbers. You don't have to accept or reject and rate this post to add information or post your comments and follow-up questions.
Posted on Jun 05, 2010
  • 3 more comments
  • latonia398 Jun 05, 2010
    Maytag Atlantis Model# MDG7400AWW
    I'm having trouble with removing the timer knob. Other knobs will come off but the timer knob seems to be secured internally?
  • Jahn27
    Jahn27 Jun 05, 2010
    The timer knob is not secured internally; wiggle it while pulling off to loosen it. Remove the console first before removing the timer knob and inspect it from inside.
    I got the console off but still can't remove knob?
    Got the knob off - it is in 2 parts - once I got the knob apart I could see that it had a plastic kind of toggle that was making it hard to remove. Removed the timer and will go get a new one on Mon am - the parts store closed at noon. Oh, well - I think I am good to go. Thanks for the help.
  • Jahn27
    Jahn27 Jun 05, 2010
    Kudos for a job well done and thanks for using Fixya.
My Maytag Atlantis Intellidry Dryer won't start unless I move it around
If you have to move the whole machine then I would say you have a bad wire somewhere. If you have to move the timer around then you have a bad timer.
Dec 28, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Intellidry cycles inoperative, regular timed cycle is fine ,Maytag Atlantis MDE7400AYW, intellidry sensor shows continunity
Howdy: It seems the "smart switch settings" has died. It is in the switching circuit. It all comes in one unit. Take it out and have it tested at an appliance store. Good luck - Doug
Dec 09, 2009 | Maytag Dryers
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
Only heats on timed drying
Our Kenmore dryer had the same sort of problem (different catchy names.
Problem was that in "smart" modes (by what ever name, the timer motor runs in series with a "dampness" sensor (thermostat, actually, I think) and A RESISTOR.
Resistor burns out--this is the symptom set.
Apr 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer Logo
90 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
