I have two computers, a new dell with all usb ports and the mouse, keyboard and speakers with it running Vista home. I would like to to share the devices with an older computer that uses ps mouse and keyboard. I have its usb ports taken up with a printer and an external hardrive. That computer is running XP pro. I was looking at the IOGear with cable two port solution and the a converter to take the output of the one mouse/keyboard and attaching to a usb to ps for the xp machine - will this work and what are you suggestions.
Buy a usb hub and an usb extension, so that you can have 4 or 6 free usb at the front of your computer, and you can switch devices using usb rather then the mouse converter . Using the converter on mouse and keybord make easier for the plugs to slip out, and usb is better. Note some usb modem and some other device do not support usb hubs, you have to plug them straight into the free computer plug , if you have any.
I have a belkin f1df102u and it does not seem to support 1440x900 resolution. Can anyone...
(More)
I have a belkin f1df102u and it does not seem to support 1440x900 resolution. Can anyone confirm?
hi i have a global 2 remote and need to store the code for a sharp combo tv/vcr vt-g21 and dont have...
(More)
hi i have a global 2 remote and need to store the code for a sharp combo tv/vcr vt-g21 and dont have the right code for it and the instruction manuel
Trying to use switch from 6 month old hp to 4 year old xp. Both computers will operate through the...
(More)
Trying to use switch from 6 month old hp to 4 year old xp. Both computers will operate through the switch on boot up, however the older computer will not connect when switching is called up, screen goes blank and usb sound is made.
