Question about Ford Garden
I am seeking parts for a Ford mower deck attachment model #09GN3697. Any help would be appreciated. Sincerely, Rob
  • 10865 Answers
SOURCE: Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: Craftsman riding mower loose belts need tighting
http://www.disruptit.com/manuals/L0403195.pdf
Here ya go.
Posted on Apr 06, 2009
wadembly
  • 448 Answers
SOURCE: I am trying to replace my mower deck belt. I
got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
Posted on Jun 08, 2009
SOURCE: Reattach mower deck spring instruction
I have a 13.5 Yardman, MTD I can figure out how to reattach the deck springs? please help.
Posted on Jul 18, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
I need a diagram on how to install the deck belt
I don't have,the make or model of the tractor,you are referring to. Hard to tell where to start in answering your question. Most mower decks have a belt installation decal,on the deck of the mower. Sorry,i couldn't be more helpful,not much to go on. There is something else you can do,if you have the Owner's Manual,there is a section,in the manual explaining,how to replace a mower belt and a section in there,that also explains,how to replace the tractor drive belt.Sincerely,Brad Locke
Oct 15, 2015 | Garden
How do I drop the lawn cutting attachment from under the tractor for inspection and lubrication?
It' pretty easy to do once the pins are removed. Make sure cutting deck is flat on the ground, on a piece of plywood. Once disconnected, raise mower deck height adjustment handle to highest position, and slide deck out from under tractor. If it's a wreck, try SearsParts online... I got a whole new deck for my LOYTH20F42T for about 125.00 delivered.
Oct 23, 2014 | Husqvarna Garden
Mower deck removal for riding mower
You need to be a bit more specific. Please post the model number of the tractor and the deck. Things change and sometimes it can be from year to year. Only way to know how yours is attached is looking up the model number to know the year and see the parts diagram.
Mar 20, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Hydraulic system
I would say,that the Motion Drive Belt,has stretched to the point,that it is slipping on the pulleys. Over time all belts stretch or break. There is no adjustment,that can be made,once stretched,its time for a new belt. Look in your Owner's Manual,to see,a picture and directions of how to remove and replace a motion drive belt. If there isn't a picture of the drive belt in your manual,then look under the left foot rest. There you will find a decal,showing the correct method to install the belt over the pulleys. This is going to be a long belt,it runs from the Transaxle to the motor's upper pulley assembly. You can,it will be hard to do,remove and replace the drive belt with the mower deck attached. First,try lowering the mower deck,to the lowest position. This will give some room,to get to the motion belt,you will have to remove the mower belt,to get to the motion belt. I find it is easier to just remove the mower deck entirely. Doing this,give you ample room to work on the motion belt. The mower belt,can be purchased from Sears Parts Direct. Give them the tractor's Model Number and the Belt Part #,if you have the number,they will look it up anyway,if not. I gave more information,than you asked for. I hope this will help you. Sincerely,Brad Locke DTD. 12/04/15
Jul 15, 2013 | Sears Craftsman 46 in Mulching Tractor...
Can any one help with my little problem--I have just purchased a murray ride on mower 12/30 model 31620x20A. it is in very good condition --but I have not got a manual with it SO my question is where can I...
Dear Jim, First thing that I would look at is: make sure that ALL of the tires have the correct inflation. It would surprise you how much lower to the ground the deck is when the tire pressures are low. Sincerely, Larry Springer
Oct 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman model 917.273482 and the deck is riding on the left wheels when it is in the fully lifted position. What did I break in the suspension of the left side I can't see anything wrong.
from the manual I just looked at,, the wheels attach to the deck on that model,, so some part is misaligned or bent,, here is the page showing the deck and wheels,, maybe it will help you http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917273482/0247/1509200/P0308003/00010?blt=06&prst=0&shdMod=917273482 You can look up the entire lawn tractor at searsdirect ,, Hope that helps Please take a moment to rate my response Thanks Good Luck
May 28, 2011 | Garden
Right mandrel assembly for craftsman model 917.273020 does the stripper, mower round attach on top of or under housing of mandrel?
The part called the stripper goes between the mandrel housing and the mower deck.
Hope this helps, if so please vote yes! Thanks!!
May 27, 2011 | Craftsman 20 hp 42 in. Deck Yard Tractor
Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
You first need to locate the model number on the mower, not the Briggs engine. Then go to searspartsdirect.com and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
May 25, 2009 | Craftsman Garden
Garden Logo
49 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
