Question about Sony VAIO M1 (VGCM1) PC Desktop
I need to build a psu for my sony vaio vgc m1 (18 pin motherboard connector) any1 know how to do this? or if any1 has a spare thanks
  • Sony Master
  • 5,660 Answers
Make a Switching Mode Power Supply? (SMPS)
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Ummm, no.
Have it repaired by a competent tech would be one solution. Pretty hard to find, as most are just glorified parts changers.
Information to pass on to the tech:
I've been searching the internet, and it seems a the R20 resistor on the circuit board, (Don't know if it's on the input base plate, or the stabilization base plate), is one component that fails.
It is a .22 Ohm resistor.
(That's point 22 Ohm, not 22 Ohm)
A competent tech will know what voltage range, and tolerance range, to use for a replacement.
The second component that seems to fail is one, or all four, of the power MOS-FET's.
(IF I understand correctly, the 07N60C3 MOS-FET's, are Infineon SPP0760C3 unit's.
Again IF I understand correctly, the Hitachi 2SK3234 may be a replacement)
The power supply used was made by Delta Electronics. It was made in Japan. The model number is DPS-197AB.
Sony's Part Number is 1-468-878-11.
The pinout of the 18-pin ATX main power cable connector, (CN1), according to my sources is;
Pin 1 - Orange - +3.3 Volts
Pin 2 - Orange - +3.3 Volts
Pin 3 - Red - +5 Volts
Pin 4 - Blue - Power Signal
Pin 5 - Green - PS-ON (With ground power source on)
Pin 6 - White - Fan -(Motherboard fan)
Pin 7 - Pink - + of Mfan (Case fan. same/same)
Pin 8 - Yellow - +12 Volts
Pin 9 - Yellow - +12 Volts
Pin 10 - Black - Ground
Pin 11 - Black - GRD
Pin 12 - Black - GRD
Pin 13 - Black - GRD
Pin 14 - Purple - +5 VSB (+5 Volt Standby. The usual 5 Volts)
Pin 15 - Gray - Power Good
Pin 16 - Black - GRD
Pin 17 - Black - GRD
Pin 18 - Yellow - +12 Volts
The PSU (Power Supply Unit) case, indicates 197.7 Watts is the maximum rated amount.
1) The 3.3 Volt power rail can handle 8 Amps (26.4 Watts)
2) The 5 Volt power rail can handle 7 Amps (35 Watts)
3) The 12 Volt power rail can handle 14 Amps (168 Watts)
Total is more like 229.4 Watts.
(Of course this power supply, probably only has a maximum sustained efficiency of 80 percent)
To you:
Fact:
A computer only uses the power it needs, and NO more. If there was a way to hook up a 1000 Watt power supply, it wouldn't hurt the computer.
IMHO, a tech will not be able to substitute the circuit board, and components, out of another power supply, and be able to fit it in the power supply case, that fits in the Sony Vaio VGC M1 All-In-One computer.
The size, and shape of the metal casing, is a Proprietary item for the Vaio VGC M1, as well as the 18-pin ATX main power cable connector.
(As you are already aware about the 18-pin connector pinout)
(Proprietary meaning made for THAT computer)
This would mean using an external power supply. Something that a professional tech is not going to approach.
Liability issues dealing with safety.
IMHO though it is a feasible approach, IF, the power supply has a metal case cover of solid design, that allows a space between it, and the replacement power supply's case.
Power supply's cases have ventilation holes in them.
What do you suppose would happen if a toddler, inserted a metal rod down into one of those ventilation holes?
Bad shock to Fatal!
Also if water were accidentally spilled on the power supply.
There would have to be a metal casing that allows an air space between it, and the replacement power supply's case, so the replacement power supply would have adequate ventilation. Would also be a safety guard.
I have also searched online, and I also concur that the Delta DPS-197AB power supply, is as rare as hen's teeth.
(Chicken hens do not have teeth)
I did see where someone on Ebay UK had one for sale, but the listing is over.
I saw a Japanese auction website that had one also, but it's listing was over.
I also saw where a person on a forum had two for sale. (Long over with)
Indication was a bad power supply, but the final diagnosis revealed the motherboard was bad.
(Food for thought)
{I also saw where a motherboard was offered on Ebay}
To conclude:
MAYBE, there is a tech that will outfit an external power supply.
Not a very aesthetic approach, but a viable one. (IMHO)
The tech will remove the 18-pin connector from the power wires of the original power supply, and insert the power wires of the replacement power supply into the 18-pin ATX main power cable connector.
Or perhaps an individual will again offer the power supply
NOTE*
DO NOT open the power supply yourself!!
There are Electrolytic Capacitors used in the power supply. (Input Stage, and Output Stage. They are used as Filters)
An Electrolytic Capacitor slowly builds up a charge, then releases it, All At Once.
They can hold a charge, once removed from power, for weeks, months, and sometimes over a year.
IF, your finger's touch the terminals on the bottom of an Electrolytic Capacitor, the charge can be released to you!
IF, your finger's touch, and complete a circuit that one, or more capacitors are in, the charge can be released to you!
Bad shock to FATAL!
There is a proper way to discharge a capacitor.
I will not list it.
Repair is for a qualified, competent repair tech.
[ http://tokyoswan.web.fc2.com/4htm/delta/delta.htm
The above link, is to show you some of the Electrolytic Capacitors used inside a Delta DPS-197AB power supply.
The link is not translated on purpose.
Scroll down to the 3rd, and 4th photo. That large Black object that looks like a Can, and has - 4742AW on it, is an Electrolytic Capacitor.
This one has enough power stored to put X's in your eyes]
Posted on Jun 05, 2010
  • joehaynes Jul 22, 2011
    I got the same power supply . I am trying to splice a normal replacement PSU . Though can get it to boot up thus far . Anyone got any advice on splicing a normal PSU to the excising connectors?
    Good post , please email me : hoehaynes@hotmail.com
How to install a power supply for vaio desktop vgc rb34g
Turn off power, remove plug from wall and power supply, Remove the 4 screws from the rear of the PSU. Open the side and unplug the cables. Remove the PSU. Refit is the reverse.
Jan 16, 2012 | Sony VAIO VGC-RB34G PC Desktop
I have Sony VGC-RB30 and after power failure it is don't start at all, I can heat clicking and green button at back is flicking, what should I do?
first you have to remove the 24 pin conncter to your motherboard from the smps and short the green and black pin and see wether the smps is working if not working change them if working remove the the four pin conector to the motherboard from the smps and switch on the computer if the processor fan is working connect back the 4 pin connector to your motherboard and switch on the computer if not working the power section in the mother board has failure you can get assistance from a chiplevel service personal
Mar 27, 2011 | Sony VAIO® VGC-RC310G PC Desktop
Sony vaio vgc-rc320p cpu fan is bad, do I need a 4 pin fan or will a 3 pin fan do?
You will need a new fan with a connector having the same number of pins which you have at present.
May 29, 2010 | Sony VAIO® VGC-RC202 PC Desktop
Of The 4 Connections On The Motherboard Is A Specific Pin Connection Critical Regarding Which One The Internal Main Hardrive Connects To?
According to specifications listed on Sony Vaio Support, the Vaio VGC-RA840G desktop computer uses a SATA harddrive.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGCRA840G
[Left-click on Marketing Specifications]
If you have four SATA headers on your motherboard, you can plug your SATA harddrive into any one of them.
The beauty of SATA is that once you plug into any SATA header, BIOS will find the harddrive. Doesn't matter which SATA connector. (Connector on a motherboard is referred to as a Header)
Photo of an average SATA header on a motherboard,
http://en.wikipedia.org/wiki/SATA
[Photo at top right of page. SATA header for this example is Red. Can be any color]
If you have any further questions concerning this, please post in a Comment.
JCV
May 18, 2010 | Sony VAIO VGC-RA840G PC Desktop
Greetings, i have a sony vaio vgc-ra820g desktop
it supports all intell processors except i7 and all amd
please vote for it and thanks for using fixya
Apr 19, 2010 | Computers & Internet
I want to upgrade the motherboard in my Sony VAIO VGC-RC110G PC Desktop. Is this possible or does sony use a nonstandard configured motherboard?
Hi:
I have only worked on one of these Sony desktops, and it is really very proprietary, where you would be better off buying a new case to install a new motherboard in. The sony looks really slick, but everything about it is odd: The power supply, the cooling fan for the cpu, etc. It would be a lot easier to save what you can and move it to a new project!
Feb 11, 2010 | Sony VAIO VGC-RC110G (VGCR110G) PC Desktop
Need the motherboard layout for this board out of viao vgc-rc110g
You will find as with Dell that the motherboard etc is all custom & you cant upgrade it yourself, you have to go through Sony. I am not 100% on that but that has been the case with many branded PCs i have seen.
Can you not open the case? This usually voids the warranty but if you were intending to replace parts then it would likely be voided anyway.
Thanks
Dec 20, 2009 | Sony VAIO® VGC-RC202 PC Desktop
Sony Vaio VGC-RB43 is flashing and computer will
try to replace power supply if no result you going need a new motherboard sorry thanks and good luck
Oct 18, 2009 | Sony VAIO VGC-RB42G PC Desktop
CPU coolers
TYPE YOU'R MODEL # INTO GOOGLE,SHOULD GIVE YOU A GOOD STARTING POINT.
Nov 06, 2008 | Sony VAIO VGC-RB50 PC Desktop
Sony VAIO M1 (VGCM1) PC Desktop Logo
1,286 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
