This particular key board does not have a Capslock light by default, So it is nothing to worry about.
Many thanks for your prompt reply.
Can you tell me if there is any software or hardware I can get to solve the problem but still keep this keyboard?
tom kane
Sir, there is no such hardware or software that i can think of which can give you a capslock warning light but still be able to use the same keyboard. I think you will need to change your keyboard just to get a Capslock warning light and that would be such a shame as this keyboard is a very good product.
First make sire your caps lock key is sitted fins on ket board.
Then pull it and clean dust from it's position on key board.
Then if still CAPS LOCK led is not flashes then you need to change that LED on keyboard.
Press SHIFT key if it change the upper and lower then go to start ->control panel->Regional and language settings Seconds TAB Languages click on details Then click on "Key settings" and make sure CAps lock option button is enable for turn off the caps lock.
Then apply and ok.
Let me know if you need further assistance.
Thanks for using FixYa.
This solution did not work
Many thanks for your advice.
tomkane
