Question about Maxtor Hard Drive
Problems installing a SATA hard drive
I am trying to install a Maxtor 260gb sata hard drive on my AsRock P4VM900-SATA2 motherboard as a replacement for my old IDE hard drive. And no matter what I do I cannot get the motherboard to recognise the new hard drive; I have followed all of the instructions in the motherboards manual but to no avail! Any help would be appreciated. Thanks Tony1955
  • Tony1955 Apr 10, 2008
    my motherboard settings are as you suggested already, but still no luck! Have you any more ideas please?
    Thnak you Tony
    I did what you said and made a floppy disk, tried it and still the same result! I am slowly getting the idea that I have a duff hard drive. any more ideas please?
    Tony
    Sergeant:
    Novelist:
  • 166 Answers
Hi Tony. As you are using a SATA hard disk then I would firstly check a few settings, this involves loading the computer BIOS. When you see the computer first turn on, you should be prompted to press "F2" to enter the BIOS screen.
From here select "Enter BIOS SETUP UTILITY" then "Advanced screen" and finally "IDE Configuration"
Verify that 1) Onboard IDE Controller is set to "Enabled"
 and          2) “SATA Operation Mode” is set to "[non-RAID]"
Once you have done this, you should see the HDD listed beside SATA 1 or SATA 2 (depending on which port you plugged the hd in to) then press F10 to save and exit. The computer will now start up as normal.
If you have more trouble after checking these settings, please write us again.
Hope this helps
Posted on Apr 10, 2008
  • Ryan Harron
    Ryan Harron Apr 10, 2008
    Hello again Tony.
    Ok now you have identified the BIOS is setup correctly, you can try using the driver for the onboard SATA/RAID device, even though you have disabled RAID some motherboards require you use the RAID driver on floppy disk, prior to installing windows.http://www.asrock.com/mb/download.asp?Mo... please navigate to here and try the driver. It has instructions included.
    Hope this helps.
How to install sata hdd for mother board asrock m266a
The drive installs physically like any any hard drive. The problem is that this motherboard does not support the SATA protocol. You would need to get an expansion PCI card SATA controller. Even then, since the motherboard BIOS is not set up for SATA, you would not be able to use the SATA drive(s) as the boot device. Also, you would need a Molex to SATA power adapter for your power supply since the SATA power connector is different. And you would need a SATA data cable if the expansion card does not come with one.
Apr 26, 2014 | Asrock M266A Motherboard
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
What type or brand of hard drive do I have to get to install in Acer AM5641 Desktop ? I want to upgrade to a 1 tb hd.
You currently have a 320GB 7200-rpm SATA II hard drive, with 8MB cache install on a base package of your make and model of computer. I would recommend a hard drive like Samsung Spinpoint F4EG 2 TB Internal hard drive. You can find it roughly for $70.00 - $90.00 at online stores like amazon, new egg, etc.
I hope this helps.
Jun 30, 2011 | Acer AM5641-B5660A Desktop PC & Monitor...
Sata problems, cant install on a new sata drive 500 gigs i want to install windows 7 any sugestion?
In Asrock support website the latest BIOS version for this motherboard is 2.30(7/11/2006). I dnt this this BIOS version will support 500GB SATA drive. Plz post a query in Asrock support forum for the BIOS that having 500GB SATA HDD support.
Jan 17, 2011 | Asrock K8Upgrade-VM800 Motherboard
I try to install winxp but it always fail and restart by itself.. my setup is: -pentium 4 630 3GHz -ocz platinum rev 2 ddr400 512MB x2 -maxtor diamond max 80GB SATA
One bad lead will cause your computer to continue in a cycle
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Sep 19, 2010 | Asrock 775VM800 Motherboard
I have a k8upgrade vm800 motherboard. I want to install a sata hdd for storage only but the bios is not seeing the sata connection. Is there any soloution to make this possible or are the sata connections...
Is the drive initialised ... if not it will not exist on your system.
1.1 Serial ATA (SATA) Hard Disks Installation
This motherboard adopts VIA VT8237 southbridge chipset that
supports Serial ATA (SATA) hard disks. You may install SATA hard
disks on this motherboard for internal storage devices. This
section will guide you to install the SATA hard disks.
STEP 1: Install the SATA hard disks into the drive bays of your
STEP 2: Connect the SATA power cable to the SATA hard disk.
STEP 3: Connect one end of the SATA data cable to the
STEP 4: Connect the other end of the SATA data cable to the
chassis.
motherboard's SATA connector.
SATA hard disk.
Nov 25, 2017 | Asrock K8Upgrade-VM800 Motherboard
I can detect no SATA' HDD
The ECS PM800-M2 only supports SATA 1.0 hard drives. If you are using a newer SATA 3.0 hard drive, there is a jumper on the hard drive which has to be set to SATA 1.0 in order for the VIA 8237R chipset southbridge (which Is on your ECS PM800-M2) to recognize the newer SATA 3.0 hard drives. This Is applicable to all motherboards with the Viatech PM800 / 8237R chipsets. Note: the location for the SATA 1.0 / 3.0 jumper varies on each brand of hard drives. Also check If SATA Is enabled In the BIOS and select IDE mode.
Apr 23, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
P4VM800 SATA HDD Problem Plz Help me!!!
Check your user documentation for the hard drive to see if it has a user-accessible jumper that will switch it to 1.5Gb mode. I know that Seagate/Maxtor drives have a jumper they refer to as Force 150 and Western Digital calls their jumper OPT1 Enabled. If this option exists with this hard disk, it should solve your problem.
Mar 21, 2009 | Asrock P4VM800 Motherboard
Maxtor Hard Drive Logo
159 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
