Question about RCA Scenium HD50LPW52 Replacement Lamp
Replaced bulb assembly in RCA DLP but screen is very dim
Hi Experts,
I just replaced the bulb/housing in my RCA Scenium HD50LP175W, but the screen is very dim. I checked all the picture settings and they're good.
No noises other than the normal stuff. I can see where the color wheel is and it looks in good shape.
Is it simply that my bulb is bad? Should I check the bulb with a meter? Please advise and thanks in advance!
    Master:
  • 347 Answers
Sounds like your light engine is damaged. Could be cracked. You can replace it for under 100.00 which includes a new engine and color wheel as well.
Posted on Aug 03, 2017
SOURCE: Buzzing noise, still have good picture
it's the colour wheel,i have replaced it once under warranty and now need another, rca and dlp ****
Posted on Sep 01, 2008
  • 18 Answers
SOURCE: dark picture on RCA Scenium 61 in DLP
Yes, the lamp will gradually get darker as it nears it's end. The rolling lines sounds more like the set is on a local channel for the cable hook up. If your local area has a channel 3 or 4 live terestrial broadcast simply tune the cable box output to the other one, the same for the tv.
If this is cable/local broadcast issue it will go away in Febuary when the NTSC broadcast ends.
Posted on Jan 15, 2009
  • 18 Answers
SOURCE: RCA 50" Scenium TV new bulb, no picture but has sound
bad color wheel
Posted on Feb 25, 2009
  • 7 Answers
SOURCE: RCA SCENIUM MODEL D44LPW134 IS MY BULB BLOWN?
If this is a DLP, which I believe it is, your bulb is blown. Look for an indicator light on the front of the tv. After you hear the bulb try to warm up two or three times the indicator light should come on and stay on steady.
I own a 57" Mitsubishi DLP and have replaced the bulb three times now. It was the latest and greatest technology when I bought it, but knowing what I know, I dont think I would buy another DLP.
By the way, get the bulb number then check ebay, by far the best prices.
Posted on Jun 02, 2009
  • 90 Answers
SOURCE: color wheel
I would make sure the assy you pulled out to get to the color wheel is pushed all the way back in. If it is then you may just need to adjust a setting in the picture menu.
Posted on Jul 09, 2009
RCA HDLP61W151 Light Engine Replacement
bulb light engine usaly seprate pices if u can open it see what were it is go for it sumtimes these very hard to getto i can try o get u serv manel online
Jan 19, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
I replaced the DLP bulb on my RCA TV, Scenium Model # HDLP50W151, and still am not getting a picture. The sound works, but the on/off button blinks indicating a bad bulb. I don`t know if bulb was damaged...
Hi there.
The guide at the following location will help you. Follow the flowcharts and you should be well on your way. It's not free, but that site is very reasonably priced and I have been most impressed with their products.
https://www.completeservicemanuals.com/Electronics/RCA/Thomson/DLP-Projection-Television/HDLP50W151-Service-Manual/prod_1663.html
Hope this helps.
Jan 11, 2011 | RCA Televison & Video
The rca scenium / src / dcr /dlp /51"/ hdtv -picture doesnot appear -could heard the sound
you need to replace the bulb. It costs about a hundered dollars and you can replace it yourself. refer to the lamp replacement instructions that came with your set
Oct 20, 2008 | RCA Scenium D40W20 40" Rear Projection...
Jul 18, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA 52" HDTV DLP tv
suspect the optical engine as the culprit. they can gather dust contamination internally and cause a "faded or washed out pic"
Apr 09, 2008 | RCA Scenium D40W20 40" Rear Projection...
"52" RCA Scenium DLP; No Picture and the buttons flash on and off
On the back of the TV, you'll find the Access door to your lamp. Unplug the TV from power, and remove the screw on the access panel. Inside you'll find 2 additional screws holding in the lamp housing assembly. Remove the screws, then the lamp assembly and visibly inpect it. You'll know if the lamp is defective, it will have obvious damage. If so replace with part # 260962, you can acquire this lamp for arround 100 dollars off ebay, or 262.00 direct from RCA.
Nov 09, 2007 | RCA HDLP50W151 50" Rear Projection HDTV
RCA Scenium HD50LPW52 Replacement Lamp Logo
222 people viewed this question
Top RCA Office Equipment & Supplies Experts
jasbo
jasbo
ray gallant
Are you a RCA Office Equipment and Supply Expert? Answer questions, earn points and help others
