Question about Hayward SUPER PUMP STRAINER COVER LID GASKET
I bought a new gasket which went in ok at first but now seems too large. I have a hayward super pump 1.5 hp. Are those gaskets designed to be glued in place?
    Guru:
  • 351 Answers
No the gaskets do not get glued in .. they should sit in a groove in the leaf catcher body.
Posted on Jun 05, 2010
Testimonial: "thanks, I wasn't sure"
Pool pump squealing
sometimes the gasket from the wet side of the pump fail and the pool water enters the bearing assembly of the pump. if there is a descent pump store, they can change the bearings within an hour. otherwise, a new pump is the solution
May 31, 2014 | Hayward 1.5hp Max Flo Inground Pool Pump #...
Vari flo handle not working properly
Which model year VariFlo?
  • Some model years do not take a spider gasket as there is spider gasket type bead molded into the diverter/key hub assembly.
  • Spider Gasket, raised bump should face up & gasket should be glued down down to prevent it moving.
  • Spring & nylon washers could also be bad.
Sep 11, 2012 | Hayward SAND FILTER, PRO SERIES
My pump is leaking .What causes that and how do I fix it
Thank youfor posting your question here on Fixya.com. The leak is likely caused by a defective pump seal. If you look at the parts breakdown at http://www.star-pool.com/assets/Hayward-Pool/Hayward-Manuals/Hayward-SP2610X15-Super-Pump-Parts-Diagram.pdf you can see the seal and the other parts that must be separated in order to replace the seal.
THE HARD WAY! Once you are sure the seal is defective you need to buy a new one along with a diffuser gasket, a pump housing gasket and some pump gasket grease.
The 4 housing cap screws and the impeller must be removed in order to remove the 4 motor cap screws. The hardest part of this process is removing the impeller. The cover on the other end of the motor should be removed and the motor shaft held with a wrench. The impeller must then be removed by turning it with a large pump pliers or by inserting a screw driver into one of the holes on the outer edge of the impeller in order to turn it counterclockwise with the shaft held with the wrench. If this damages the impeller it should be replaced.
Now remove the 4 motor cap screws and everything is apart except the seal. Half of the seal can be removed from the motor shaft and the other half from the seal plate. Placing a socket on the back side of the seal that is on the seal plate allows the seal to be removed by tapping it with a heavier tool (hammer or pump pliers). Clean this area, apply a little silicon adhesive to the area and insert the new seal half into the seal plate using the instructions that are included with the seal.
Use pump gasket grease on the pump impeller gasket and reassemble the completely reassemble the pump.
THE EASY WAY!
Remove the piping from the motor and the electrical conduit and wires from the end of the motor. Bring the pump to Leslies pool supplies (I don't work there or own any of their stock) . If they are not very busy then they will do the above and only charge you for the parts while you wait.
I have replaced so many seals I almost always do it myself at the pool site but it is not easy for the first timer.
Ifthis answer does not resolve your issue, please comment with additional informationbefore rating the answer. Positive feedback is especially appreciated once yourproblem is solved! Thank you.
Aug 28, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Leaks from the pump housing
PUMP HOUSING LEAKS.. 3 THINGS COME TO MIND.# 1 IS THE SHAFT SEAL #2 IS THE TANK GASKET IS BAD, OR THE DREADED TANK BODY IS CRACKED. NOT UNCOMMON FOR THESE PUMPS. TAKE PUMP APART (MOTOR OFF) LET SIT AND DRY A LITTLE AND YOU WILL NEED TO LOOK CLOSE AND THE CRACKS STICK OUT BETTER WHEN SLIGHTLY DRY. IF IT IS CRACKED, THERE IS NO FIXING IT WITH GLUE. IT MUST BE REPLACED. IF IT COMES TO THAT POINT , I WOULD RECOMMEND A STA RITE DURA GLASS . 1 HP. THE SUPER PUMP YOU HAVE IS NOT THAT EFFICIENT. THEREFORE I RECOMMEND THE SR 1 HP. IT WILL SAVE YOU ON POWER ALSO , HEY YOU .. REMEMBER TO PRIME THE PUMP AFTER ANY PUMP REPAIR !!!... JAY FLORIDA
Jun 09, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I have a Hayward super pump. I just changed the housing gasket, but it is still leaking from somewhere at the bottom. I can't see where it is exactly leaking because there is no clearance between the pump...
You forgot to replace the most important part...The" shaft seal".It is behind the impeller. Be sure to remove all the pieces of the old seal off the impeller ,(they always come off in pieces) and put silicone on the rubber part that sets in the pump housing. Make sure you keep the white porcelain surface perfectly clean, and you will also need to replace the ribbon gasket again.
Sep 30, 2010 | Hayward 1 12 Hp Super Swimming Pool Pump...
Hayward 1 hp pump clicks then shuts off
If it has an internal centrifugal switch, usually under the cover at the rear of the pump, it might be stuck. Check it got movement. The weights on the switch move out away from the shaft when starting. If that is ok, possible capacitor.
Jun 05, 2010 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward vari flo valve
It will not be glued, it is just stuck in there good. You will need to scrape, pull, twist or otherwise convince it to come out as best you can and then clean the area well before installing the new one.
Jul 14, 2009 | Hayward 3/4hp Super Pump Inground Pool...
If the spider gasket in the vari-flo valve is no good, you will usually notice one of two problems.
1. Water leaking out backwash port while filter is operating.
2. Valve positions are really difficult to change.
The way to check this is if you are able to move one or two of the "spokes" in the gasket freely(out of the track it sits in) once the top of the valve is removed.
If so you need to replace. The gasket is usually held in with a silicone sealant. Once you remove the old gasket. You will need to scrape any remaining rubber from the track it sits in. I've found that a brass brush from a pluming supply store or home depot along with a flat head screwdriver is usually enough to do the removal.
I always used Permatex Blue RTV sealant on all valve jobs. It can be found at any auto parts store or sometimes Walmart. Follow the instructions for curing. Once cured the gasket is good as new.
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Hayward SUPER PUMP STRAINER COVER  LID GASKET Logo
115 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
