Question about Whirlpool Duet GHW9150P Front Load Washer
The inside washing "cylinder" is detached from washing machine unit...can this be fixed?
    Sergeant:
    Champion:
  • 311 Answers
Anything can be fixed- just a matter of how much money you want to spend doing it. Refer to the warranty as this part may be free if you pay an authorized svcr to fix it.
Posted on Jun 05, 2010
Asko WCAM1812 makes noise when draining
I recently had this same problem. There is a spinning wheel inside the pump that has likely detached from the motor. Upon removing the back of the unit, you will see a water pump on the bottom left of the unit. There are three screws attaching the pump to the rest of the assembly, remove the screws and detach the motor, out should pop out a red spinning wheel. I Gorilla glued mine back on, and it sounds better than before the grinding noise.
Feb 13, 2013 | Asko WCAM1812 Front Load Washer / Dryer
LG washer model wm2301hw won't turn on
We had the same problem (washer would not turn on). The problem was a small fuse blown in the power noise filter unit. The unit is a plastic block near the top of the washer on the inside - connected to the power cord. It is a very commonly produced unit and goes in a number appliances. The fuse inside fails frequently (so I hear) and is extremely difficult to replace due to the protective-covering material so it's easier to just replace the whole unit. I purchased a replacement unit for about $30.
Very easy fix:
1. Unplug the washing machine.
2. Take off the top of the washing machine (two screws in the back)
3. Identify the noise filter unit (top of washing machine, hanging on the right with the power cord attached to it).
4. Remove with one screw and unplug the two cables going into the noise filter unit. Slide out the unit.
5. Put in new unit. Screw it in, and plug the two cables into it.
6. Put the top of the washing machine back on (not necessary to test if the new unit works)
7. Plug in washer and run.
https://www.encompassparts.com/item/7814463/LG_Electronics/6201EC1006L/Filter_Assembly
http://www.amazon.com/LGE-ZENITH-FILTER-ASSEMBLY-6201EC1006L/dp/B006E7V7DW
Oct 18, 2012 | LG WM2301HW Front Load Washer
Zanussi washing machine
Open the door and grab the inside drum top and bottom, Wiggle back and forward, if it makes a knocking sound then either the bearings are worn or the drum has become detached from the bearing mount.
Mar 08, 2012 | Zanussi Washing Machines
Washing machine doesnt spin
the problem sounds like the motor to gearbox drive this is two plastic and a rubber unit which is between the motor and gearcase.you need to detach the motor to gain access to this part,should cost you around 20 pounds.
Apr 12, 2010 | Whirlpool LSQ9600L Top Load Washer
WASHING MACHINE LEAKING FROM BOTTOM
Check the two lengths of 1/4" plastic tubing, the long one that runs from the filler at the botton left side of the tub, and the short one that runs from the load switch (water level switch) to the shield assembly (formed plastic cover for the controls). When under pressure, the tubing can come loose from the plastic nipple on either side of the shield, leaking water while the tub is filling. If either length of tubing is detached from the nipple, reattach the tubing and use a 1/4" hose clamp to prevent it from detaching again.
Mar 14, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
BLACK TAR-LIKE DEPOSITS INSIDE WASHER BASKET
THE DRUM INCLINE BOTH PLASTIC AND MEATAL SCRATCHING FROM DRUM CAUSE LIKE A CRAYON /SMALL PARTICLES , THE SUPPORT SPRING BESIDE THE DRUM ARE DETACHED NEED TO INSTALL SPRING / AVAILABLE IN APPLIANCES CENTER.
Jan 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Checkign lid switch for maytag washer
unplug the power cable open [panel chech wiring detached /mostly some wiring detach was the line of starter switch / the water valve wiring detached / the machine will pour water if valve are malfanction insert the wire . then ok.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machine stopped through cycle and now will not turn on
I can help with this. I work on the units they make. If you can email me @ curator@artinallforms.com I will guide you through
Jun 16, 2007 | Fisher Paykel EcoSmart GWL15
Whirlpool Duet GHW9150P Front Load Washer Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
