Question about Dell Dimension 3100 PC Desktop
Booth up the computer
I tried to booth up the computer, I typed f1 and f2 but it still won't start. What to do.
    Guru:
  • 383 Answers
Remove the memory slot clean it with soft cloth then back it again or check computer cables..if not working reformat pc
Posted on Jun 05, 2010
  • 4,281 Answers
First When you power up the computer press F1 or F2 or del or ALt+F2 to enter in bios.Then make sure harddrive is detected.
If you harddrive is not detected or you can't see any display on screen then open cpu cabinet.
Reattach the RAM memory ,both connection to harddrive .Reconnect processor and it's fan pull cmos cell from motherboard for 10 minutes.Remove pci card or vga card if any then check.Make sure motherboard is not ground with cabinet.
Let me know if you need further assistance.
Thanks for using FixYa.
How do I go to BIOS?
You can enter BIOS setup or UEFI firmware via traditional method: Boot the PC, while the firmware starts to run, press F2/F1(Fn+F1 or Fn+F2). However, computer boots fast, maybe you often miss the trick to press F2/F1(Fn+F1 or Fn+F2). You can enter UEFI firmware from windows 8 or 8.1.
Nov 02, 2016 | Computers & Internet
Ever time I start my computer I have to Ihit F1
go into bios and change your boot up start from CD/DVD to hard drive then you wont get f1-f2 error.
Jan 21, 2014 | Dell XPS Computers & Internet
What do you do if it blinks and you tried pressing f9,f2,f1,etc. and it won't work?
Remove the main battery and try again, if no! sub out the ram one at a time and test each, if still no result! the motherboard has a major issue.
Apr 29, 2012 | ASUS Eee PC 1000H Laptop
Pls help me out to get my password
1. Boot up your computer and immediately hold down f1. If it boots up normally then restart your computer and try f2. try all of the f keys and try del or esc until it boots up into your BIOS setup. This will look like a bunch of very blocky graphics. (usually the buttons are either f1, f2, f8, f10, del, or esc)
2. Once in your BIOS, navigate with the arrow keys and enter until you find the option to boot into "safe mode with command prompt" select that option, save your preferences and reboot your computer.
3.Once you've booted into safe mode, log on as the administrator or guest. Usually it does not require a password.
4. At the command prompt type "net user *" but type that without quotes and where it says you're user name just type you're user name without the 's.
5. It will ask you for a password. Type in the password you would like (It won't show the keys or even * that you are typing so that's ok). It will ask you to retype the password so do that.
6. reboot your computer and hold down whichever key that you used to get into setup.
7. Once in setup change the option from booting into "safe mode with command prompt" to the default option which will usually say boot into windows or something to that effect.
8. Log in as yourself using the password that you typed in at the command prompt.
Hope that helps
May 08, 2011 | Computers & Internet
How do you get into the bios on a 785gt-e63 msi motherboard? read the book it said at start up press f1 did not work.
As soon as you turn on the computer start tapping (not fast, but steady) the F1 key, you could try F2, DEL, and other various keys that work on other boards.
Usually the screen will show you what to press in the corner or somewhere on the screen.
F12 for boot / F2 for BIOS / etc
Or it might say Press F1 or F2 or something to enter Set-up.
You have to catch it before the computer starts to boot into your operating system.
At this point you can push the power button for half a second and the computer should turn off instantly as you have not started booting up the computer.
Then you can try another key to enter the BIOS.
After locating the manual and skimming through it, I see that it states you need to press the DEL key to enter setup (BIOS).
Hopefully that helps.
Aug 26, 2010 | Intel Motherboard
I was working on my computer this morning and it froze. I turned it off and restarted it. The screen was black. I then turned it off and restarted again. Said something like default press F1 or F2 to...
At this point, you have to get all your data removed from the hard drive and then install the operating system of your choice. If you need further assistance, please give us a call at 800-595-3564.
Jan 18, 2010 | Acer Aspire 5100-3357 Notebook
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Laptop won't boot up.
http://www.cgsecurity.org/wiki/CmosPwd I have used this program at school to bypass bios passwords and i find it to work well.
You may also try to type Toshiba where it asks for the password.
Mar 10, 2009 | Toshiba Satellite A65-S126 Notebook
Problem when i start my computer have a choice F1 and F2
just insert the xp cd and choose repair in it .......it will remove the error message
Jun 20, 2008 | 10 10 Computer Network adapter Cable...
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
IBM - PC, XT, AT
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
http://www.wnycomputerpro.com
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Dell Dimension 3100 PC Desktop Logo
94 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
