Question about Briggs & Stratton Gas Pressure Washer 20244
I have a Quantum Gold 2300PSI 6.0hp pressure washer and can not get it started. Can you help me.
3 Suggested Answers
jeff_drakesr
  • 155 Answers
SOURCE: Gas powered pressure washer wont start
On pressure washers the more you pull the cord the more pressure builds up making it difficult to pull and start. I hold the trigger down as i pull this keeps the pressure down. If this is not the problem then take a look at the Spark plug, Air Filter if all is fine then check the fuel. How often do you use it, fuel loses its Octane when sitting around. Please give a 4 THUMBS UP if this free answer is helpful in anyways. Good Luck and have a Great Day.
Posted on Apr 02, 2010
jyackle5
  • 8197 Answers
SOURCE: Need a owners manual for
Do you have a model # so I can help you find the manual
Posted on Jul 28, 2011
Testimonial: "Great job"
What do I need to have done with the backfiring & stoppage?
check wiring to the ignition switch for shorts or loose connections or breaks
the problem is intermittent connection for the coil or ignition source
Jun 12, 2016 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Have a Excell 2300psi pressure washer. Pull cord
yes very short ones. or pop rivet back on . easy and inexpensive
Oct 11, 2014 | Garden
Low pressure
faulty pump. check each valve for obstruction or fault
Apr 05, 2014 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Small clear hose on Honda power washer
Sounds like the hose that goes into the detergent bottle.
Mar 21, 2014 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Poured oil in the gas tank by mistake of Honda water pressure model GCV160. Drained the gas tank, changed spark plug, drained carburetor still will not start
Sounds like you have oil in the gas galleries of the carb. Fill it with gas turn gas valve on and try starting it a few times with starting fluid to help rince/thin them out so gas can flow through them again. It may smoke more than usual for a while. Dont keep it running on the starting fluid though as it has no lubrication for the cylinder/rings and could scar the cylinder walls. If that doesnt work you can remove it and try to do it manually with a can of carb cleaner or get a new carb. They're on ebay for about $20 or a small engine supllier near you will have one for about the same or a little higher.
Dec 24, 2013 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
Need a owners manual for Craftsman Power Wash- Quantum Gold 6.0 2300psi
Jul 28, 2011 | Garden
Hi i have a briggs and stratton pressure washer cv 2300psi omb 6.75 horse power 2.0 gpm .It was working about amonth ago and jus stop.I pull the string a couple of times and nothing,so i left it .Can you...
hi marlo. check the fuel level, the air filter, and the spark plug. clean or replace as necessary. then get a can of starter fluid and an assistant. give the air intake area, by the air filter a couple of squirts of starter fluid and then start it up. keep it running by squirting more starter fluid for up to 2 minutes until it will run on it's own. J.
Jul 15, 2011 | Briggs & Stratton Gas Pressure Washer...
Apr 02, 2010 | Briggs & Stratton Gas Pressure Washer...
I have a craftsman 4.5hp quantum xte pressure washer 1800psi/4.5hp/2.0gpm mod 580.761800. I have to start the washer before I turn the water on and just today started with if I let go of the trigger on the...
the pressure relief valve(bypass) is most likely stuck or clogged. take the relief valve off and check for broken or jammed parts..there should be a bypass hose that goes around the pressure valve
Jun 16, 2009 | Briggs & Stratton Garden
Briggs & Stratton Gas Pressure Washer 20244 Logo
703 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
