Question about Garden
Ryobi rcs3535.pull start operates easily when plug removed.when plug is replaced the pull start has so much resistance that turning the engine over requires too much effort and it is extremley jerky.
    Brigadier General:
  • 4,088 Answers
Remove the spark plug, ignition off, and open the choke and throttle. Turn the saw upside down and pull the starter through vigorously to see if the engine expels any fuel. Replace the plug and see if there is any change. Does the engine have a compression release? If so, it may be plugged with carbon--remove and clean or replace it. Modern saws seem to have more compression than earlier saws. I have a new, small Husky saw that is equally hard to pull and no compression release. The cure is to sell this one and find a saw with a compression release, or one that is otherwise not so hard to pull through. Good luck!
Posted on Jun 05, 2010
How do you test the ignition coil on 410r Ryobi tiller?
with a multimeter set on ohms resistance and in the coil wiring
you can also test by removing the plug , using a new plug connect the ht wire to the plug and ground the body of the plug onto metal of the engine-- problem
pull the cord fast and check for a spark across the plug gap
good blue spark --not a coil problem
check the air gap between the coil and the flywheel ( .005 to .010" gap) coils seldom fail and it generally the plug or switch wires that are at fault
Aug 01, 2017 | Ryobi Garden
I have replaced spark plug, gasolines w/fuel filter, and carburetor but ryobi s430 still won't start.
Make sure that all of your fuel lines are good with no leaks and cracks. Ditto for primer bulb. If all ok, then you need to clean out carb, or get a kit for it.
Apr 10, 2017 | Ryobi Garden
Briggs and Stratton 5hp starter shaft doesn't engage
use the free sign and encourage people to take it
Apr 12, 2017 | Atlas Translator Garden
When I remove the spark plug, the pull rope operates easily. When the spark plug is in, the pull rope is "jammed". It will not move.
remove the muffler and check the exhaust port and the condition of the cylinder and piston.
Nov 29, 2009 | Ryobi Garden
Problem with Ryobi Restarting
you need to replace the fuel filter in the tank ,must be fished out of tank with a coat hanger to the filler hole to be replaced
Sep 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Engine won't Start on Ryobi RCS 4046C
no spark at plug sends you back to magnita/transformer. ohm it out to see if it has resistance. it should read low resistance. good luck and have a great day please rate bama46, thanks
Aug 16, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
May 12, 2009 | Ryobi Backpack Blower 25.4cc
Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Jul 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi RLT30CES
I also tried this.
  1. Clean the carb wire gauze air filter behind the roto-choke knob. (undo the nut/washers & long bolt)
  2. Deteremine if fuel is being fed to cylinder - Fully depress & prime the bulb about 7 times, turn to full choke. Pull start cord about 7 times. Remove spark plug see/smell fuel fumes/vapour present in cylinder
  3. Determine if compression is weak - remove plug, put finger over plug port, pull start cord. Should be evident of resistance/pressure build up when cord is pulled.
  4. Of course brand new plug!!! as above (I would try this first)
Hope this helps
please rate my comments - Thanks
Aky1967
Jun 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
