Question about Olevia LT23HVX 23 in. LCD Television
Broken screen I have a rectangular shape of colored lines and impressions on one side of my 32inch how can I fix
    Scholar:
  • 121 Answers
What do you mean by impressions? Are you talking about ghost images from image sticking?
Posted on Jun 05, 2010
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
Oct 12, 2016 | Toshiba Televison & Video
Manual for a 95 pontiac sunfire
Refer to a repair manual for exact location and picture of what it looks like. Generally charcoal canister is located in 1 of 2 places, under hood passenger side ( shaped like a can ) or under the body, usually a ( rectangular shape ),somewhere in middle area, made of plastic and black in color.
Apr 06, 2013 | 1995 Pontiac Sunfire
My 32inch tv turns on but the picture is wired.
On a 32 inch it may not be worth fixing--not going to be a reset etc--base decision on fact that possible repair should not exceed used value of set--which in my view it likely will.
May 26, 2012 | Hannspree (K206-10U1-005) Television
First there was a burning smell, then the picture was very dim.. Now no picture at all, just multi colored vertical lines, with a small spot that has a web like look to it. Does this sound repairable? or...
Hi
This is more than likely your screen controller board that has gone faulty, if the lines cover the screen vertically and are very thin and rainbow kind of coulored then i would say 98% this is the faulty board, Remove the back from your tv and look for a little board (rectangular in shape) that connects to your screen. (Middle top)
Get the part number of the board and Google or Ebay for a replacement.
Hope this helps
Mar 11, 2010 | Proscan 42LA45H 42 in. LCD TV
I was given a rca p61940 rear projection tv. The
It sounds like a convegence problem due to dust on the lenses. Clean the lenses with qtips and alcohol and then use auto convergence in the menu screen.
Mar 08, 2010 | RCA P61940 61" Rear Projection Television
Need to know what color wires run my mass air flow sensor in my 93 maxda mx3 1.8l should be 2 wires what color and where to find then
You can pick up a Haynes manual. They have all necessary diagrams in them, including electrical schematics.
Regards,
matt
Sep 15, 2009 | 1993 Mazda MX-3
I need to find a wiring diagram for a 73 corvette on the coil
Look at the HEI distributor. You will see a rectangle shape coming out of the side of the coil cap. Observing it closer, you will see that there is abbreviations on it, raised up from the rectangular area.
BATT is Battery. This is where the thick Red wire goes. It comes from the starter, but doesw not receive power until the ignition switch is turned to the On position.
TACH is Tachometer. This is a wire smaller than the BATT wire, and is usually Brown in color, but color codes vary. May be Blue.
There are three flat blades, looking underneath this rectangular shape.
Flipping it back and forth, you can see that one of the outside flat blades, goes to the Batt wire.
The other outside flat blade goes to the Tach wire.
The middle flat blade goes to Ground.
Apr 16, 2009 | 1965 Chevrolet Corvette
Rectangular shape with knobs light on my 2003 VW Passat
Could it be a battery shape? Red in color - means "Generator". VW recommends not driving if this stays on. Alternator belts may be loose or broken and/or electrical malfunction
Dec 12, 2008 | 2003 Volkswagen Passat
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Televison & Video Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
