Question about Hawke Sport Optics Hawke® Endurance MAP 3 - 9x40 mm Rifle Scope Matte Black
Hawke HK3102 internal ocular lens unseated
I have a Hawke HK3102 rifle scope. When firing my 5.56mm rifle the internal ocular lens (eye end of scope) became unseated. I can see it lying on its side by looking through the scope. The scope is now unusable. How do I fix?
  • 2,100 Answers
You probably can't fix it, and I don't know if it is worth fixing. There is a guy on ebay that fixes scopes, but like I said, this might not be worth fixing. you can buy a new one for what it will cost. So considering it a total loss, it won't hurt for you to try. You can take off the rear just by unscrewing it, and then the cross hair tube will come out, all different, but usually a cylinder screw driver, ( a tube with 2 notches on it, or a flat piece of steel the diameter of the inside tube. ) Take it out and see what happens next, going in from the front will release the seal, but it might already be broken. If you end up with a basket case, put it on ebay for parts. Hope this helps.
Posted on Jul 25, 2010
Can i fit my scope on a tika 3006
You can fit a hawke sidewinder to your rifle
Mar 27, 2015 | Hawke Sport Optics 8-32x56 SideWinder 30...
Rifle scope adjustment
Just snugged as you may want to change it later
Oct 30, 2013 | Hawke Sport Optics Optics
Even though the scope was marked 22mag could it still be used with out damage on a regular 30-06 rifle, thanks for your time
Everything I could find on your scope says that it can be done, provided that you can get the correct mounts.
It looks like the optics will be able to handle the stronger kick of your '06, but because they are much smaller than a full-sized rifle scope at 32mm, you will be limiting yourself because the scope cannot drink in as much light for the longer ranges that the '06 is capable of.
One thing that you have to be careful of is that since a .30-06 kicks ALLOT more than a .22, that you set the scope far enough back so that it does not hit your eye when you fire. You do NOT want your eye right up against it, because after you fire your rifle you will get a bloody black eye!
You should seriously consider a scope with a larger aperture. If cost is a problem, Look around at Sportsman's guide.... I got a real nice 6X29 40mm BSA scope from them for about 80 bucks!
Mar 10, 2011 | Simmons 511072 3-9x32 A/O 22 MAG...
How do i use a tasco 28A
1. Insert the Bore Stud into the Stanchion while aligning the arrows as shows. Insert the assembled scope guide into the muzzle of your rifle with the grid pattern upright. 2. Select the Aperture Cap that fits your objective rim. Place it over the objective end of your rifle scope and press until it fits flatly against the rim. 3. Using the Adjustable Scale measure the top of your rifle scope tube to the center of the rifle bore as follows: Open the rifle breach. Rest the upper arm of the scale on the scope tube before or behind the windage and elevation turrets. The scale markings should be facing towards you reading vertically and ascending from bottom to top. Slide the lower end of the scale up or down until it is touching the center point of the bore. On center fire rifles the center point will be the firing pin. On rimfire models the center will be the shell extractor. Read the number that corresponds to the indicator marked "CF". Make a note of the reading. 4. Aim the rifle toward a light, flatly lit area such as a wall or open sky. Caution: Do Not Look At The Sun As Permanent Eye Injury Could Result. 5. While keeping the riflescope at the right distance to see the full field of view, sight through it on the grid pattern. Move the stanchion right or left until the bold centerline is parallel to the vertical reticule wire. Turn the windage dial right or left until the vertical reticule is aligned with the grid centerline. 6. Use the reading from the scale to align the horizontal reticule wire. Find the numbered horizontal grid line that corresponds to the number on the scale. Turn the elevation dial right or left until the horizontal reticule wire aligns with this corresponding grid line. 7. To make your final zeroing adjustments remove the scope guide from the bore of your rifle. WARNING: FIREING YOUR RIFLE WITHOUT REMOVING THE SCOPE GUIDE MAY CAUSE DAMAGE TO YOUR RIFLE AND OR CAUSE YOU INJURY At a range or other safe area test fire a group of three rounds of the same type ammunition at a target at least 50 yards away. Refine your scope alignment by adjusting the windage and elevation dials. Move to your desired distance from the target and test fire another group and make your final windage and elevation adjustments. 8. Restore the stud tension by pressing the end of the spring.
Feb 13, 2011 | Tasco Scope Guide Quickly Zeroing Rifle...
Using the scope
Well if it was a rifle, I would say far away, or you will get a black eye. But the recoil on a pellet rifle is backwards because the spring jerks the rifle forward, and it messes with rifle scopes, they are made to recoil back, But,,, you have a movable eyepiece in the end where you look through and it will make the cross hairs come into focus for your eyes. some one else might find them blurry. The objective lens, should be in focus no matter what. It doesn't move. and no matter what your vision is, you should be able to see clearly. If not, I'm wondering if it is fogged up. Your eye should be about 3inches, + -, Check it out. Hope this helps.
May 04, 2010 | Crosman 4 x 32 Air Rifle Scope, Black
I need to replace the battery on my centerpoint scope
I'm not sure which model you have but the most common battery location is under the reticle switch on the ocular lens housing, you have to hold the base of the switch with one hand and turn off the cover with a coin in the other hand. The most common battery for these scopes is a CR2032 button style battery.
Hope this helps, Mark the Gunsmith
Please leave feedback, Thanks!
Dec 05, 2009 | Centerpoint Technologies CenterPoint AR22...
Need the rubber eyegaurd for a Bushnell Sportview rifle scope
if you need the rubber eye guard for this rifle scope you are using it all wrong,,,if your eye is so close to the end bell of the scope your going to get a very black eye,,,there is at least 2 inches of eye releaf on this scope so there is no reson to have a rubber bit on the end at all, i have 3 of the bushnell scops on my rifles a ,,,7.62,, .303,,,22.250 and none have the rubber on them,,,so far iv never had a black eye!
Nov 15, 2009 | Bushnell 3-9x38 Sportview Rifle Scope...
Whitch way do my lenses go?
If you completely disassembled the scope then it is compromised they have a special gas mixture inside for fogging and clarity so if they were removed you are likely better off with a new one out of reference what kind of scope is it
Apr 02, 2009 | Hawke Sport Optics Hawke® Endurance MAP 3...
I need a scope guide instruction sheet for the Tasco 28a
Dec 14, 2008 | Tasco Scope Guide Quickly Zeroing Rifle...
Hawke Sport Optics Hawke® Endurance MAP 3 - 9x40 mm Rifle Scope Matte Black Logo
187 people viewed this question
Top Hawke Sport Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Hawke Sport Optics Optic Expert? Answer questions, earn points and help others
