Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
The distance from the coil to magneto,should it be touching or is there a feeler gage setting on Hayter harrier lawn mower 41
  • 1,675 Answers
Hi this should have a gaged gap to be honest i cant remember what it is, but is definitely should not be touching...hope that helps sorta..
Posted on Jun 05, 2010
.000 gap for the coil?
not near enough information so a guess answer will have to do
If you are referring to the flywheel to magneto coil clearance on lawn mowers or trimmer motors
place a .005 " feeler strip between the items and adjust the coil to touch the strip
lock in place then carefully remove the strip as you turn the flywheel
Sep 07, 2017 | Garden
What is the air gap set at to set the timing
Normally you just set the air gap so it is as close as possible without touching.
May 21, 2016 | Stihl Models 064, 066, Ms640, Ms660
Where is the oil drain on hayter harrier 41
quite likely it is under the desk where the blade is .
Jul 12, 2015 | Garden
Which way does the bolt turn to remove the blade from a hayter harrier 41 mower
You can figure this out by checking the direction that the blade turns when it is operating and the bolt will tighten the opposite way because if it turned the same way it would loosen off when the motor was turning the blade, so almost univerdsally it will loosen clockwise and tighten counterclockwise.
Sep 19, 2014 | Garden
Hayter harrier lawn mower why slow going up a slight incline but runs away going down
Indicates lack of power, but that is normal to a degree. Are you saying it's worsened? Start by cleaning thoroughly then drain all fuel and put freshly bought fuel in. Then you can start to fault find if it's still bad.
Jul 15, 2014 | Garden
Starting my petrol mower
depending on age of machine set the throttle to maximum revs,and pull the starter cord but newer models have a primer button located on carburettor which is locked just under air filter (black or red colour) push it three times( you should hear it inject fuel) and then pull starter cord,some of these engines have a pre-set throttle ,main concern is that if it has not been used for some time you will need to clean carburettor out,replace diaphragm and remember to use fresh fuel(not older than 90 days) this should cure your problem
Mar 22, 2009 | Garden
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
459 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Daryl Gleaton
obsteiner
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
