Question about Sony PlayStation 3 40GB System
The playstation has power but when i try to turn it on the green light turns slightly orange and then it shuts back down and the red light flashes. i did just have a lightning storm so im hoping it didnt get fried
  • 146 Answers
It is the ylod caused by the lead free soldier they now use on the cpu. needs to be re-flowed, sent back to sony or sell for parts hope its helps you. also you tube ylod it will show you
Posted on Jun 05, 2010
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops...
this happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Ps3 shutdown?
hi..Seems like your Power Supply went dead or either a faulty button.. Since those are touch pads those sometimes wear out. Another issue could be due to overheating..
thank u
rate me
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
VT440K orange power flashing red status light, overheated.
Make sure all the air filter caps are all the way in and nothing is broken from it. that was my cause..i had the same problem
Apr 17, 2009 | NEC (50019497) Projector Lamp for VT440,...
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Open Questions:
Sony PlayStation 3 40GB System Logo
66 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
