Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Why can't I install my new kodak 3250 and get it to run properly I have tried to uninstall it but it won't any suggestions ?
    President:
  • 4,070 Answers
Hi! Some installation requires the usb and power cable to be unattached before proceding. Uninstall it and disonnect the usb and power cable before reinstalling. This can resolve the problem. Hope this helps and have a good one!
Posted on Jun 05, 2010
I have a kodak 3250 printer...it will not take the que from the computer to "print".....it copies just fine...just will not print from the computer..have checked all connections
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Oct 30, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Error code 3508 after installing a new cartridge
As Kodak suggests in these cases - upgrade the firmware for your printer.
  1. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
If the error continues, try to contact Kodak
Oct 03, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Ineed to reinstall kodak esp 3250 printer scanner but do not have disc tryed to use it but came up error 101 2015 how can iset it up again withuot disc thank you alan
From the Kodak website:
For error codes 101-3011 or greater, follow the instructions provided in the message text box. If the error persists:
  1. Uninstall any All-in-One Printer Software installed on your computer:
    Select Start > Control Panel > Add or Remove Programs > KODAK AiO Home Center Software.
  2. Select Change/Remove.
  3. Restart your computer, then log in as administrator.
  4. Close any programs that are open, including those that appear on your computer taskbar.
  5. Confirm that your computer is connected to the Internet.
    NOTE: If your connection to the Internet is wireless, verify that the signal strength is sufficient.
  6. Install the latest version of all-in-one printer software.
    1. Locate and select the software for your operating system.
    2. Follow the instructions to install the software.
      NOTE: If you don't have access to the Internet, install all-in-one printer software from the CD that was supplied with your printer.
Although your error message is different, the above is basically a good piece of advice. Do a clean reboot, and uninstall anything to do with the Kodak printer.
The driver you need can be downloaded here: KODAK DRIVER
Sep 21, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Hi...I have a Kodak, 3250 3n1 printer. When I bought this printer several months ago, I loaded the cd and walked thru the exact instructions to download the scanner. Everything worked great!...I was able...
Reboot your computer as well as your scanner, also check your data cable if properly connected as well as the power cord of your scanner, else try to uninstall your printer/scanner and reinstall it again. Reboot again and try connecting again. Usually, it is not possible to use your scanner simultaneously while printing.
Jul 05, 2017 | Kodak Esp 3250 Allinone Multifunction ( ...
I have just purchased an new computer and am running windows7 on a 64bit machine. I have tried several times to install the Kodak software from the disk provided with my printer which worked OK on my last...
32 bit and 64 bit drivers are not compatible. So for 64 bit operational system you have to install 64 bit drivers for your Kodak Easyshare 5100. I found link for you:
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9099&product=EKN033539
I am strongly suggesting uninstall everything what are you installed ignoring warnings about incopatibility before installing proper drivers! Good luck! :-)
Sep 27, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 3250 printer (brand new) wont scan, issues an error 2005 warning??? Help. I've followed Kodaks troubleshooting instructions to no avail. I've also uninstalled and reloaded...nada, nothing...ziltch...
From Kodak's website:
Answer : To resolve error code 2005, 2006, 2007, 2008, 2009, 2036, 2105, or 2106:
1. Go to www.kodak.com/go/2005 to run SSEUtility.exe.
2. Do one of the following depending on your browser:
- WINDOWS Internet Explorer: Click Run, then click Fix.
- MOZILLA Firefox: Click Save, then double-click SSEUtility.exe.
3. Try to install the KODAK All-in-One Printer Software.
4. If the following message window appears, your processor supports SSE and the utility will not be able to help.
Click the X in the upper-right corner to close window.
5. If the problem continues or you were not able to use the utility, contact Kodak (1-800-421-6699)
Dec 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
180 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
