Question about RCA RS2620 Single Cassette Deck
Hi, I have a RS2620 and the Casette belt is broken... where can I find the casette belt? Help
  • RCA Master
  • 5,151 Answers
All you have to do is measure the diameter of the belt (in mm) and the put that and Cassette belt into Google. If you live in the UK Maplin have a range of them.
Posted on Jun 23, 2010
Sony stereo casette deck TC-wr531, tape is stuck
The mechanism can not complete a cycle due to dried out lub and maybe a stretched belt- do not think like a lot of people do that the belt is the only answer as this will lead to a still broken deck.
Feb 17, 2014 | Audio Players & Recorders
Hello i have a jvc rv b 90 . Ive insert the casette wrong. Now i cant open the casette deck anymore.
Hello
Casette tape can be reeled to the capstan shaft and jammed. It is a tricky way to get it out. Only an experienced service technician can do this work. If you try to pull the casette hold tray out by force, it will get broken, and will turn irreparable. OK.
Oct 02, 2011 | JVC RV-B90 Boombox
We have a Sylvania TV/VCR combo with a tape inside that won't eject. The result is that the TV shuts off after a couple of seconds. The model number is SSC192
Hello
The belts in the VCR mechanism should be replaced. They are loose and elongatee. Due to this, proper loading of casette won't take place. If so, the video casette will not load properly, willl stop at its middle, will cause a short for the secondary supply; and finally will shut down the TV, and that is happens now with your device now. The inserted casette wont come out. You ahve to open the system, and take the casette out manually by turning the mechanism. If you have enough knoledge you can do it by yoursef. If not get it repaired by any experienced service technician. Never switch ON and OFF this set at this condition. It will make mor faults to get in with power supply system. OK.
Aug 08, 2011 | Sylvania Televison & Video
I want to transfer casettes to a cd.
Hi
To transfer any audio or video casette to cd you need an audio casette player/vcp or vcr for playing back the video on the computer, a video capture card installed on the computer and the software to capture the video like Pinnacle which will save the audio/video file in mp3, mpeg format on the computer. The casette player or the vcr can be attached to the computer tower through the video capture card.
Jun 15, 2009 | Computers & Internet
Casette deck drive belts broken
If they are just worn then you just need to look where they go. Take a photo or draw it! If they are broken and not clear how they attached then it will be hard. You might need the service manual if that is the case.
Jun 06, 2009 | Pioneer Audio Players & Recorders
Casette
You could have one of several problems. The cleaning message comes up when the camcorder cannot read the signal from the tape properly. This can be caused by:
1) A dirty video head
2) the tape guides being out of alignment
3) A worn or broken video head
If a cleaning cassette head does not help, you will need a tech to look at it.
Oct 18, 2008 | JVC GR-D90U Camcorder
Sony dual casette player/recorder
Unit may have slipping drive due to defective belt or tape may have wrapped around captsan. Have serviced
Jul 28, 2008 | Sony Dual-Deck Cassette Player/Recorder...
ERROR: please remove the casette
There is likely a problem with the transport mechanism. This is something that should be serviced be a professional repair shop.
Sep 12, 2007 | Canon Elura 2 Mini DV Digital Camcorder
SERIES LXI TV & vhS
I'm guessing the "black thing in side" is referring to the actual tape itself- ribbon like which can be spooled out of the tape case. If so, then your VCR may have a mechanical problem of some sort, which results in a "no tape transport" or "no tape takeup" problem. If the latter, the right reel (takeup reel) is not being driven. Older VCRs often used a small rubber rimmed drive mechanism to drive this reel. Newer VCRs (10 years old or less) pretty much use a gear drive. Something may be broken here, or perhaps the gear is stuck. This gear assembly has to swivel back and forth, from left for rewind, to right for takeup or fast-forward. Unfortunately, you can't see the gear once the tape is in the machine, at least not from the topside. Suggestion: Take the top cover of VCR off, look for this gear, and see if it swivels freely, look for broken gear teeth.
Apr 14, 2007 | Rio Go Video DDV9475 Dual Deck VCR
Put tape in new video cassette
TAKING A GOOD QUALITY TAPE FROM ONE CASETTE AND MOVE TO ANOTHER WITHOUT HARMING THE TAPE QUALITY: TAKE A NEW, GOOD CASETTE AND UNSCREW THE 5 SCREWS HOLDING THE TWO PARTS OF THE CASETTE TOGETHER. AT THIS POINT DO NOT OPEN THE CASETTE. TURN THE CASETTE UPSIDE DOWN (SO THAT THE SIDE WHERE THE SCREWS CAME OUT IS NOW SITTING DOWNWARDS ON A FLAT SURFACE) IF YOU OPEN THE CASETTE BEFORE TURNING IT UPSIDE DOWN, ALL KINDS OF SMALL PIECES WILL FALL OUT AND YOU WILL NOT KNOW WHERE THEY CAME FROM. NOW GENTLY SEPARATE THE TWO PARTS OF THE CASETTE AND PAY ATTENTION TO EXACTLY WHERE THE TAPE RUNS THROUGH VARIOUS SPINDLES, ETC. MAKE A SKETCH IF THIS WILL HELP YOU. GENTLY LIFT OUT THE TAPE AND REPLACE IT WITH THE TAPE THAT WAS IN THE BROKEN CASETTE. THIS IS ASSUMING THAT THE ONLY DAMAGE WAS TO THE CASETTE ITSELF AND NOT THE TAPE. REPLACE THE TOP PART OF THE CASETTE (WITH THE SCREW HOLDS STILL FACING DOWNWARDS). HOLDING THE TWO PIECES OF THE CASETTE TIGHTLY TOGETHER, TURN IT OVER AND REPLACE THE SCREWS. TRY NOT TO HANDLE THE TAPE ITSELF. I HAVE USED RIGHT FITTING SURGEON'S GLOVES WHILE DOING THIS, BUT REALLY DON'T KNOW IF THEY HELP, BUT THEY DO KEEP THE NATURAL OILS OF THE FINGERS OFF THE TAPE.
Feb 26, 2006 | JVC HR-J461MS VHS VCR
RCA RS2620 Single Cassette Deck Logo
170 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
