Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Grennish/yellow spots pt-50lc14
After reading on here that the green or yellow spot are a eprom update that is needed I called Panasonic and she stated that panasonic is not aware of any problem with the pt 50lc14 and green or yellow spots... Please help.. Johnny
  • 1 more comment
  • rakan Oct 27, 2008
    yellowish tint on pt 50 lc 14 how can i trouble shoot and how do i fix it? any websites that might show me the proper way of repairing this
  • danschubert Nov 11, 2008
    I must have the same problem. Its on the lower left side of my screen.
  • bwgraphics Mar 24, 2009
    have the same problem, the yellow tint is in the center left of the screen fades up and down from there
  • 3 Answers
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Duane
Posted on Jun 04, 2008
Gohnny,
I also have several yellow blobs on my TV (PT-50LC14). It is due to a burnt polarizer filter just past the blue filter for the blue chip. This TV is a three chip design with red, blue and green chips.
I am currently trying to get a new polarizer filter from Panasonic.
Duane at duanetr@sbcglobal.net
Posted on May 02, 2008
Spots all over the tv panasonic pt-61lcx65
If they are large colored circles behind the picture scenes, mine had it too. Fix was as simple as service technician plugging into the EPROM and loading a software update. Picture then was better than day1.
Jan 06, 2014 | Televison & Video
I have a green spot in the upper left corner when watching tv . Is there a repair for this problem?
The spots are caused by errors in the eeprom affecting the optical engine data. The fix is easy but it will have to be done by an authorized Panasonic shop. Call your toll free customer line at panasonic to find out, but I'm sure the repair should be covered under warranty regardless of the age of the unit. Thx
Bill W.
integrityhomeworx.com
Mar 07, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
On my Panasonic 52'' HDTV (PT-52KCX65) I have a real bright green spot on the screen about 6 inches in diameter and is about a foot from the left and centered up and down. What is t he problem and what do...
Eprom correction tool is used by servicer to remove spots. If he calls Panosonic tech line and mentions Fuzzy spots they will give him and auth number and pay for the service.
Nov 23, 2009 | Panasonic PT-52LCX66 Projection Television
Rear Projection TV -- Bright spot with yellow edges on TV screen
if it is a panasonic pt-50lc14 then you will need a new bulb. you can find them online, do a yahoo or nextag search for the ty-la 1000 bulb and you can find them for around $100...
Mar 11, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Green and red spots on panasonic tv
eeprom update. call your local AUTHORIZED Panasonic repair shop. They should have an eeprom update tool.
Dec 23, 2008 | Panasonic PT-52LCX65 44" HDTV
Pt-52lcx65 52 in.
call panasonic customer service....open a claim....problem is most likely that the eprom needs to be reflashed.....i contacted them several weeks ago, told them my problem which was 5 baseball sized colored spots, 1 red, 2 blue and 2 green. they had me perform a couple of tests using a dvd. when i reported the results they set up a service call with a local authorized repair shop. results were amazing. reflashing the eprom took about 4-6 minutes. in addition my brilliant color returned to the set as well as another problem of neon images going away. this was paid for by panasonic. my set was 2 years over warranty. panasonic has issued a service bulletin on this and are backing up these units.
pt-61lcx35
hope this helps, i am quite satisfied with what was done.
Dec 18, 2008 | Panasonic PT-52LCX65 44" HDTV
Spots on picture
I had the same problem. Panasonic is kind of a pain about the whole thing. You have to find out who your local Panasonic repair place is, tell them there is a service bulletin and they will get on it. You must be diligent! Do not take no for an answer! If it comes down to it, and the repair shop won't do it for you, then call Panasonic and endure a loooooong wait time. Trust me though...this is the issue. Once the eeprom gets fixed/updated/whatever, the picture looks amazing! Good luck.
Aug 16, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
PT44LCX65 Has spots and Haze
Panasonic has a fix for this problem. No need to replace the light engine. Just have a service tech do an "eprom upgrade" - Fixed mine.
Jan 24, 2008 | Panasonic PT-52LCX65 44" HDTV
HELP Green spots
"eprom upgrade" by a Panasonic tech will solve your problem...
Dec 27, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-52LCX15 green spot on screen
Easy fix. I had the same green dot problem and I removed the front panel (no screws). In the center is a panel that has two screws. Remove them and pull the cover off. There you will find the projection bulb. Do not clean the bulb but instead the base. Use a damp cloth to wipe the dust off the black disk (the base of the projection bulb housing). Apparently the dust through static electricity may cause enough magnetism to distort your picture. Hope this helps.
JK
Oct 04, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
1,611 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
