Question about Cutler Hammer Ch220gf Circuit Breaker
220 dryer CH Breaker only trips partially and dryer does not reach full heat. Is breaker problem or dryer?
    Guru:
  • 351 Answers
I would say that the problem is in the dryer, but only tripping partially is not exactly right either. It is easy and relatiuvely less expensive to replace the breaker . $40 .. if you replace the breaker and still get it tripping after a few minutes of opperating the dryer , then it is time to call a service tech for the dryer.
IF the breaker trips immediately when connecting the dryer, then unplug the dryer and try again, to see if there is a wiring problem in the line before the dryer.
Posted on Jun 05, 2010
Why wont dryer heat up after changing out coil ?
most dryers are 220. its possible your breaker is half tripped. try cycling the breaker.. you should get 220 across it while its running. (Be careful).
Sep 09, 2015 | Haier Dryers
WHIRLPOOL DRYER WONT HEAT
1st thing is to reset the house breaker for the dryer, it is a 220 volt breaker, the dryer only needs 110 volts to run but needs 220 to heat, so the breaker can be partially tripped which will only allow for it to run but not heat. If that is good make sure where the cord attaches to dryer terminal block isn't burnt up, you can lose 220 there as well. If you have 220 to the dryer then you either have a bad element or thermal cutout located on the element with the hi limit thermostat, those parts can be tested for continuity out of operating condition
Jan 31, 2014 | Whirlpool Dryers
My dryer is not heating I replace the thermal fuse, coil valve, thermal cutoff, and thermostat fix and still not heating what can I do now.
Did you verify that 220 volts is actually getting into the machine?
Dryers are using slightly more current and many older breakers are tripping on 1/2 of the circuit. The dryer runs but no heat because the breaker has tripped. USUALLY you cannot see the tripped breaker as it is bridged to the breaker for the other 1/2 of the 220. Somewhat firmly, turn the breaker fully off. Not to the tripped position, but fully, completely, stoutly OFF, then back on.
If this turns out to be your condition, and it happens again, get an electrician to look at the circuit, you don't want an overheat or fire.
Doc
Aug 03, 2013 | Kitchen Ranges
Does Not Shut Off
1st go the the house breaker (dbl breaker) for the dryer and shut it off and turn it back on, your dryer runs on 220 volts of power but if the breaker is partially tripped it may be only running on 110 volts which is only enough power to turn the lights on and to turn the drum the element needs 220 volts to turn on. If it still doesn't heat after resetting the breaker then you may need a heating element or thermostat. The dryer isn't shutting off because it isn't detecting the clothes are getting dry so once you fix your heating problem the dryer should start shutting off on its own again.
Apr 21, 2012 | Roper Dryers
I inherited an older model whirlpool electric dryer when I moved in...there seems to be no heat...went to get clothes out this morning and they were still damp...I wasn't given a manual - and have...
Check the breakers, by FULLY turning it off and then back on. What happens, commonly, is the heat side of the 220 breaker trips. If it keeps happening, sometimes you need a new breaker, but DO NOT increase the amp rating of the breaker. Breakers that trip from time to time, eventually start tripping EARLIER.
Jun 10, 2011 | Whirlpool Dryers
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
My house circuit breaker kept tripping and
sounds like your heating element has opened up it was probably partially shorted to the case and this was causing your breaker arcing condition previously
Sep 24, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
The dryer will not turn on. I know I have power because the light is on. But nothing happens when I hit start
Check for a tripped circuit breaker (a ganged double breaker), sometimes only one breaker trips without tripping the other. Switch breakers off and then back on. If you have access to a voltmeter, check for 220 volts AC at the the two slanted slots in the dryer socket. Occasionally, one breaker of the pair will fail internally--replace the pair. If 220 volts is present, then problem is internal to the dryer. Usually, it is a short circuit in the heating element which causes the circuit breaker trip.
Jul 16, 2009 | Dryers
Drying Machine Problem
Hi..
If your dryer is not drying,
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating elementOften a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Regards
PCmania
Jul 16, 2009 | Whirlpool Dryers
Kenmore 70 series dryer works but no heat
check your power if one leg is down eg 110 to the motor drier will run but not heat if the heater is getting 110 but not the motor drier will do nothing check for a partial tripped breaker eg one side tripped but not fully just turn off and reset check outlet for 220 check power cord at terminal block for loose or burned cord unplug first lol if cord is burned just means it was loose when in stalled most of the time this promb is elec.
Dec 28, 2007 | Kenmore 63942 Dryer
Cutler Hammer Ch220gf Circuit Breaker Logo
182 people viewed this question
Top Cutler Hammer Electrical Supplies Experts
Steve
Hippy_dd
Gene Haynes
Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
