Question about ASUS Z71 (90-N9Q1G1000) (90N9Q1G1000) CD-RW/DVD-ROM (Combo) Burner
1996 z71 silverado x cab
Changed out radio and now a/c wont work or blow thru the vents
I had this problem with my 2005 z71 xcab. It was all about the battery being disconnected; the ac's control module had to be reset. We turned off the truck and pulled all of the fuses related to the AC, turned the truck on, put the fuses back, then let it run for awhile. It didn't work at first but the next morning, voila! it was fine. Might also try having the dealer reset the truck's computer to the factory settings. It's a pain but it works too.
Posted on Oct 09, 2008
2002 Silverado wont change from defrost to floor
either the heater control or the lil motor that adjusts the door is shot.
i believe the motor is on top of the heater box behind the radio for the vent function there is also a blend door motor on the side (hot to cold) of the heater box.unplug the vent motor cycle the defrost/ floor knob and test for power . no power bad heater control .power present bad vent door motor. auto wreckers are the best place for these parts (cheapest) some will also test/ install
Mar 07, 2015 | 2002 Chevrolet Silverado 1500
1999 z71 air conditioning randomly stops blowing
If the air stops blowing from the vents, the problem is with the blower motor. If it doesn't come on, try slapping the motor with your hand. If it starts when slapped, replace the motor.
Do It Yourself Diagnosis and Repair
Aug 14, 2017 | 1999 Chevrolet Silverado 1500
I have a 2003 silverado reg cab v6. when i start i hear this clicking sound coming from under dash somewhere.. but only last about 30 seconds and stops.. and once clicking stops AC/heat does not work thru...
have the vehicle checked for a vacumm leak,sounds like a blend door accuator problem,maybe closing up on you when starting,some heat/ac systems work off vacumm so get checked underdash and hood,hope this helps
Sep 09, 2011 | 2003 Chevrolet Silverado 1500
Ac started blowing hot air on my 2005 chevy z71 half ton crew cab ac blower was working fine just started blowing hot air
The seal package in your unit leaked out the freaon. It will have to be resealed again and recharged.
Jul 27, 2010 | 2005 Chevrolet Silverado 1500 2WD
2000 Silverado Z71 Ext cab - dome light not working. Is it as simple as changing the bulb and if so how do you get if off?
Usually you just grab the edge and pull or pry gently with a screwdriver. and yes, you can just replace the bulb.
Nov 20, 2009 | 2000 Chevrolet Silverado
2000 Chevy Z-71 A/C problems
maybe drop the blower motor and check the vents for obstructions. I worked on a friend's car this spring that had a two year-old repair bill sucked in to the blower wheel....it limited the air output but made a lots of noise in the process.
Jun 24, 2009 | 2000 Chevrolet Silverado 1500
Computers & Internet Logo
169 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
