Question about Sub-Zero 561 / F
Ice maker won't work - Sub-Zero 561 / F
    Scholar:
  • 44 Answers
Before you replace the Water Valver -Shut your water off - disconnect the water line to the from the back of the refrigerator at the top where it goes into the icemaker. I used zip tie or something flexable item to see if it would go all the way through to the
tube inside the refrig. If you have obstruction - use your hair dryer
to thaw the ice from inside the refrigerator tube. When the flexable goes all the way through. Hook back the water line to the icemaker. You will have ice soon. If Still not working, replace the water inlet valve at bottom back right of refrig.
Read more: http://forum.appliancepartspros.com/refrigerator-freezer-repair/93259-ice-maker-repair.html#post227249#ixzz0pzmjhvPC
Posted on Jun 05, 2010
Whirlpool Ice maker broken
First review this YouTube video about how to fix a current Whirlpool ice maker that does not make ice. Most are fixable. (The maker of the video, Repair Clinic, will work with you to find the exact part needed and sell you that part. Excellent company to work with.
Whirlpool Freezer Won Make Ice Ice Maker Assembly W10190965
You can determine which ice maker you need by checking at the Whirlpool website on icemakers.
Whirlpool Refrigerator Ice Makers Replacement Parts Accessories PartSelect
If you have determined that you cannot fix your existing icemaker, try checking Amazon for a replacement.
Amazon com whirlpool ice maker replacement
Feb 09, 2018 | Whirlpool Refrigerators
Ge profile PFSF6PKXEWW AFTER POWER OUTAGE ICE MAKER DOESMN'T WORK
If the ice maker is not filling with water after dropping the last harvest of ice cubes it will indicate a defective WR57X10091 Water Inlet Valve If you would like to try self diagnostics on your model click HERE and go to page 78, I will be here should you have questions, Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
I changed the water filter, now the ice maker won't work.
Probably water Inlet Valve is bad and needs replacing.
Nov 27, 2017 | LG Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
My ice maker on Maytag MF12468AE stopped making ice. When I add water to the tray, the cubes form but are not ejected. Is the the water valve bad or is the entire ice maker itself bad?
The ice maker is bad and they have been discontinued by the manufacturer. Luckily, there is a replacement part that works in your machine, part number W10477228. The reason I say its bad is because it should have atleast ejected the ice that was made when you poured water in it if it were working properly. The only other thing it could be is that the temperature is not cold enough in the ice maker area, which is 10 degrees F or colder. If the temperature isn't at least that then the ice maker won't cycle at all.
Jun 05, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Ge psc25pssc ss
Ice maker - don't work anymore. Ice cubes are small and wet. Water running down the sides of the freezer. Water in ice maker won't freeze.
Apr 20, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice maker won't make ice
This problem is very common.The ice maker water passing line gets clogged or blocked by ice cube or gets frosted by ice or the water valve,which lets water to ice maker,tray, that valve gets faulty.
The ice maker not working.-------------
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Oct 10, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Refrigerators Logo
176 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
