Question about Dishwashers
Hi i have a Candy CDI 1012/B Intergrated dishwasher and 4 lights are flashing during the first programme then system drains and stops showing four lights lit. We have no instruction manual or service manual this would be good to get hold of as we have serveral of these machines. any idea what the problem is to save us time investigating it. Thanks Paul
  • 19,396 Answers
Hi. The four leds flashing quickly at start of the cycle means that there is an inlet problem. Check that the inlet hose is not bent, blocked or kinked, ensure that water has sufficient pressure. The inlet valve can be tested reading Ohms at valve terminals. If valve is faulty, the solenoid contacts will read open using a multimeter set on Ohms (infinite Ohms). If water is filling correctly, then the problem is usually the water level switch. The switch can be tested removing it from appliance and ensuring that it is opening and closing, or in a simpler and more efficient way, by jumping its contacts. Other way to check inlet is by jumping door switch and observing what happens by starting a cycle with door open (it must be done by a tech). Some of the testing described is only suitable for a trained technician. Here the user manual: CDI 1012 (41012895)en Regarding the service manual, I have different CDI series manuals, but most of my service documents from Candy are in Italian (it is an italian brand). I do not have the CDI 1012, I uploded here the CDI 45:Candy dish cdi45_32900048.pdf, I hope it can help to locate parts. Regards. Ginko.
Posted on Jun 05, 2010
Diplomat intergrated dishwasher error code FA
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
Candy cdi 1012/2-80 is leaking at bott of door. Whats up.
my candy dishwasher is leeking from the bottom of door what can i do
Nov 23, 2010 | Candy DFI Plan Built-In Dishwasher
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
Candy dishwasher CDl 1012/2-80, program stuck?
Hi Derek if its only been used about as you say ten times it will stil be under gaurantee,just call the supplier and have them solve the problem for you mate it sounds as if the program selector is faulty as it is all eletronic programming and could even be a faulty circuit board.
hope this helps
regards JL
Oct 04, 2009 | Candy Dishwashers
Candy Dfi 85s intergrated dishwasher
candy dishwasher wont turn on , lights are out , it is plugged in any ideas please ?
Mar 02, 2009 | Candy DFI Plan Built-In Dishwasher
Candy cdi 1012 dishwasher
Did anyone ever manage to work out what the cause of this was? Our dishwasher is exactly the same. We had it fixed once under warranty and it lasted about a year before breaking again. Unfortunately we never asked what work was done during the first repair. Thanks. Stuart
Dec 20, 2008 | Candy DFI Plan Built-In Dishwasher
Dishwasher wont complete program 1 2 or 3
Did you ever resolve this problem with your dishwasher, unfortunately i've exactly the same type of problem!
Thanks Steve
Dec 18, 2008 | Dishwashers
Candy CDI 1012 Dishwasher
providing its not under guarantee remove mains plug and remove door skin from front of door carefully, as it has to go back on, look for any broken wires just above the door hinge, there will be about 10 or 15 wires, its possible that if you have checked what you said have checked properly that one of these wires has got hot and broken (very common fault of all dishwashers aver 3 year old) replace wire with care etc, work safely,
Oct 06, 2007 | Candy 17 in. CS455 Built-in Dishwasher
Dishwashers Logo
637 people viewed this question
Top Dishwashers Experts
Owen Barnes
