Question about Garden
How to adjust electric clutch on westwood mower v20/50
4 Suggested Answers
  • 95 Answers
SOURCE: electric clutch
Ebay
Posted on Aug 17, 2009
  • 10 Answers
SOURCE: my westwood ride on mower, model 2012 wont start.
Could be a few things, First, you say it's getting fuel, but is the fuel fresh? It may have water in it and act like your engine. Did this problem just start happening? Did you happen to ride over something that may have sheared the key on the flywheel? This would throw the timing off on the engine. If you can try to start it while spraying gas into the carb throat and it keeps running, then it could just be a dirty caburetor or a misadjusted carb float. Good luck, Bill
Posted on Dec 21, 2009
riceski
  • 1851 Answers
SOURCE: I have a husqvarna lawn
Remove the blades first. Drive the unit up on two ramps - one ramp for each side of the mower. This allows you a look from the bottom up. Firs look for some small wire rope that might have some how gotten lodged in there. Also check the clutch switch to be sure the machine thinks all your safety relays are engaged. This is important. Check to see if the blades will spin a little AFTER you take off the plug wires and BEFORE you remove the blades. This is very dangerous if you leave the plug wires on as on occasion this can result in death if the unit cranks up and it does indeed happen. If the unit spins a little - you may find you need a spindle or two. You can remove the deck as the easiest way to get this done. I highly recommend removing the deck at this point and give it the once over - even check the belt and also check to be sure the blades are perfectly level. I am fairly sure that once you remove the deck you will find a bad spindle / bearing.
Let me know of your progress
Gary @ Fix Ya
Posted on Aug 15, 2011
I need parts for a T1200 Westwood ride on lawn mower,cant find
Westwood Parts ' eBay
www.ebay.co.uk/bhp/westwood-parts
Find great deals on eBay for Westwood Parts in Lawnmower Parts and Accessories. Shop with ... COUNTAX WESTWOOD Parts Garden Tractor Breaking For Parts ... Westwood Countax T1200 Ignition On Off Starter Switch Repl Part No/ 1649.
BREAKING FOR SPARES WESTWOOD T1200 1400 RIDE ON ... - eBay
www.ebay.co.uk > Garden & Patio > Lawnmowers > Lawnmower Parts & Accessories £0.99 - ‎In stock
Breaking for parts - Westwood T1200, 1400 & 1600 years 1987-92. ... Ignition Starter Switch Fits Some WESTWOOD T1200 Ride On Lawnmower 1649.
Westwood Tractor Spares - Largest Genuine Spare Parts Dealer
www.westwoodtractorspares.co.uk/ Genuine Westwood spare parts dealer. Huge range of parts in stock for all models including T Series, S Series, X Series, W Series, V20/50 Series. We ship ...
Westwood T1200 Ride on Tractor Mower Parts
www.japgmowers.co.uk/westwood-t1200-ride-on-tractor-mower-parts-56-c.asp Mower Deck Parts Parts, spares and accessories for Westwood T1200 Ride on ... Westwood S1200, T1100, T1200 PGC Sweeper Grass Collector Drive V Belt ...
Westwood Parts - Buyamower.co.uk
www.buyamower.co.uk/category/westwood-parts.aspx Genuine Westwood Spare Parts. ... At Buyamower, we are Westwood main dealers and as such we stock thousands of ... Westwood Lawn Tractor Blades.
Westwood Parts Manual : Beltingonline.com, Supplier of power ...
www.beltingonline.com/garden...belts.../westwood.../westwood-parts-manual-850/ Beltingonline.com : Westwood Parts Manual - Rubber Timing Belts Garden Machinery ... Westwood Tractors Parts lists for ALL Models by year of manufacture ...
parts for T1200 Westwood ride on lawn mower Google Search
Apr 01, 2017 | Garden
Electric PTO clutch on a LX255 John Deere I want to remove it and disassemble it to repair it
Electric Clutch Adjusting and Troubleshooting for Lawn ...
? 7:05
www.youtube.com/watch?v=yB9Lf_NKYXw
Oct 15, 2011 - Uploaded by askanthonynow This video describes how to adjust an electric clutch on a lawnmower. ... How To Repair Ripped Out Wires On An ElectricalPTO Blade Clutch - Duration: ... John Deere: How to change bearings in the deck spindles - Duration: .
Aug 25, 2015 | Garden
Electric pto wii not engage?
how do you know it's actually getting to the clutch ???
is there a ground for the clutch too ???
is the clutch adjustable ???
Aug 29, 2014 | Garden
Westwood 1300s red hot exhaust
Get carb. adjusted, way to rich.
Mar 30, 2014 | Briggs & Stratton Garden
How do you adjust the electric clutch 180505
depends if it's adjustable or not remove mower deck and look at motor shaft you'll see clutch (it's got a wire going to it) if three springs are held in with rivets then it's not adjustable you'll need to relpace it if it's got three phillips head screws then in a alternate pattern try tighting each one half a turn and test it , if screws bottom out replace clutch
Nov 21, 2013 | Craftsman Garden
I have just fitted a new transmission belt to my westwood 1012, it will go into gear when the motor is off but when the motor is running the gears will not engage when the clutch is pressed
You've probably put the belt on incorrectly or not put the clutch wheel or spring back correctly. When you press the clutch a jockey wheel on the drive belt should release the tension, allowing the belt to slip and the gears to be engaged.
Oct 28, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
How do i adjust the the clutch?
there is a clutch for the drive and a clutch for the blades, would help if you specified which. Generally there are two kinds of mower clutch, one is electric and not adjustable, the other is a spring loaded pulley to put tension on the belt. When the belt stretches, the pulley splits, or the spring weakens this type of clutch may need one or all of those components replaced to restore tension, but it is not "adjustable" per se. half the time the owner has put the belt back on wrong and there is no tension so exclude that possibility before you start buying parts.
Apr 22, 2011 | Craftsman 20 hp 42 in. Deck Yard Tractor
Electric clutch adjustment
.012" is the recommended air gap for the electric clutch. Use a feeler guage in the slots beside the nuts and check in circular pattern. Go at least 3 complete circles with your guage when adjusting.
Hope this helps,
Dolf-
Oct 14, 2009 | Garden
I have acquired a Westwood T1300 Hydra Ride on Mower but it came without the instruction manual; can you provide me with one, please Roger Dennett Tel: 07816 152 705 rogerdennett@questsourcingt.biz
here is one on ebay. there are also many hits on google
http://cgi.ebay.co.uk/Westwood-S-T-Ride-On-Lawn-Tractor-Parts-Manual-1990-00_W0QQitemZ220485655907QQcmdZViewItemQQimsxq20090926?IMSfp=TL090926143003r8795
Oct 03, 2009 | Garden
Garden Logo
171 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
