Question about Sharp AF-S120FX Air Conditioner
My unit shut off now displays E1.
My unit shut and willnot turn back on. it keeps flashing E1.need help gettng it to work think theres a code to fix it but dont have it.
  • 3 Answers
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Posted on Jul 05, 2010
I have a model AF-S125FX and holding the power button doesn't work to reset unit.
I was told by a Sharpe CSR that if holding the power button doesn't do it try holding the "mode" button instead.
1 Disconnect power plug
2 Hold down MODE button, plug in power cord,hold
MODE button until you hear a beep, the unit will
start
3 Press power button to shut off
4 Press power button to restart
This worked for me.
Gary
Posted on Aug 11, 2010
  • 30 Answers
Check the manuals and go to error guide you will found the meaning of E1.
Posted on Jun 05, 2010
4 Suggested Answers
SOURCE: unit stops working - E1
I wrote the solution #1 and have an additional comment. This really does work!! I fixed my neighbor's AC unit by following the instructions for clearing the E1 code. The unit will not operate until the code is cleared. The page is titled: Customer assistance for air filters cleaning (E1 code) on Sharp Air Conditioners
Posted on Sep 07, 2007
SOURCE: help
go to sharpusa.com and click on support, they have all the model airconditioners and all the help. its in pdf format and i dont know how to paste the info. really easy problem to fix.
Basically, tells you to make sure air filter is clean.Unplug from wall, then hold Power/on/off button down and plug unit in wall. press Power/on/off button until you hear a beeping sound(approx 5 sec) then disconnect powerplug from wall. plug back in and start your ac again. it should work!
If this dont work try the same thing but by pressing the Mode button and same kind of operation as above, but the unit will start to operate after you press mode and herar the beeps. turn off by pressing On/off button. then start as normal. if you cant get it go visit the website.
Posted on Jul 28, 2008
bobicehouse
  • 1524 Answers
SOURCE: we have an E1 code
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Posted on Jul 22, 2011
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
I have a Sharp AF-S80FX A.C. unit. Whether on cool or fan the unit keeps tripping the breaker on the plug with an E1 message. The filter has been removed and cleaned, but it really wasn't dirty.
small_16_7.jpg For a detailed Air Conditioner illustration, click below.
redarrow.gif Window
It doesn't turn on at all
The fan runs but there's no cold air
The air is cool but doesn't seem cold enough
The unit never turns off
There is water sloshing around inside
The unit tries to start for a few seconds and then quits
A motor is running but there is no air blowing
The unit rattles loudly when it turns off
Water leaks out the front of the unit
The air smells musty
Note: If your repair problem isn't listed, click here
Check to see if there is power getting to the air conditioner. If it is a 110-volt unit, plug a lamp or other device into the same outlet the air conditioner is plugged into. If there's no power, check the fuses or circuit breakers. If there's still no power, you will need to contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it is still completely dead there may be a problem in one or more of the following areas:
Jul 10, 2008 | Sharp Heating & Cooling
E1 error code displays when unit is plugged in I have a wall unit with about 10,000 BTU capacity. Two days ago, it quit working and displayed the E1 error code. I unplugged the unit, let it sit for 10...
highly annoying issue error code E1. After hours
of fan operation, the error code E1 will appear on the seven segment
LED temperature display. This error code is intended as a reminder for
the user to clean the air filter. However, because the procedure
outlined in the user manual does not clear this error code as
indicated, and the appliance has a nonvolatile memory that cannot be
reset by simply unplugging it, the user of the appliance will become
mightily frustrated, standing in potentially sweltering heat watching
the appliance repeatedly shut down in the midst of operation with the
"E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the
"E1" code from the display, and plug it back in and re-start it, it
will simply run for anywhere from a few minutes to a few hours, and
then merrily shut down again with the same flashing "E1" code.
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
Many people at this point, having put the manual under the canary or
some such, will simply return the unit and never buy another Sharp air
conditioner. But for the tech-savvy and search-adept, I offer the
following procedure to clear the nefarious E1 indication, and obtain
1. Power down the air conditioner using the "power" button on the front
panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine
goes through a brief test sequence (fan & compressor each come on
briefly, etc). There is a "beep" sound at the end of the test sequence,
and the machine will be off. At this point, you can release the power
button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed
the instructions above EXACTLY.
_____________________________________________________
Was this solution helpful? Show your Appreciation by rating it.
Thanks for using fixya support..You have a wonderful day
Jun 05, 2008 | Haier hwr10xc6 Air Conditioner
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
We have a portable air conditioner. It keeps
Follow the steps below....
panel.
button.
Jun 26, 2010 | Heating & Cooling
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Electric dryer E1
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Dec 09, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer (5yrs old)
screen.
➔ Press Control On
➔ Press Start
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Delonghi Dehumidifier DE400P / DH400P says error Code E1
Hi.
It is simple and easy to fix. E1 code for sensor behind right side grill. Take right side grill out, unplug sensor from wire socker and plug back. It is solve problem sometimes. Unit MUST be unplugged from outlet.
If no help, you need new sensor .
Thank you.
Dimitry.
Nov 10, 2007 | Dehumidifiers
Unit stops working - E1
Aug 25, 2007 | Sharp AF-S80FX Air Conditioner
Sharp AF-S120FX Air Conditioner Logo
1,832 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
