Question about Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman 54" deck tractor engine won't turn over
When I turn the key, the engine won't turn over. I've replaced 2 fuses, 1 spark plug (going to replace the other today), cleaned the air filter, new oil filter, changed the oil and a new battery. The tractor is fairly new (2007). I've evened charged the battery and jumped it, just in case. But it still won't turn over. The fan will get going and everything, and there is spark and the fuel hose is functioning fine (sucking). I was going to try replacing the solenoid, but if that doesn't work, any other suggestions? Carberator maybe?
  • 36 Answers
Your problem is electrical clean all connections from battery to starter then if that don't work then change selenoid,does the lights and all the gauges work? write back and let me no if that works.
Posted on Jun 05, 2010
What is the gap gauge for craftsman pyt 9000 lawn tractor 26hp
If you are talking about the spark plug, I would need the model number of the engine.
Jun 15, 2014 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Huskee madel 13af673h131, won't crank
I guess you were sitting on the seat while trying to start the unit, so Try to apply power direct to the starter, if it turns over buy a solinoid. If it doesn't the starter may be bad. To check the engine: take out the spark plugs and try to turn over the engine from underneath by hand, using the pulley. This will tell if the engine is siezed up
Apr 10, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Fuses location for craftsman 26 hp 54" deck mower
Replace start fuse on right side of motor by oil drain plug.
May 04, 2013 | Craftsman 26 Hp 54" Deck Yard Tractor
Will not start no spark
check all fuses and does headlights come on when you turn the key on
Oct 26, 2012 | Craftsman 26 Hp 54" Deck Yard Tractor
26 hp 54 inch craftsman mower will not cramk over. sounds like turns over once than no more. replaced battery and same issue
try you and jump start the engine direct to the starter if you have a bad battery cable it will not carry the amps needed if still no luck remove the spark plugs to see how it cranks over if spins over fine you might have a bad compression release system on the cam shaft if fluid spits out the carb could be leaking into the engine
Jun 29, 2012 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I just put a new carb on my 17.5 hp lawn tractor .... it starts and runs great then after about 2 minutes it cut out .... and won't start for a few minutes .... spark is good ...... any ideas? it is...
It is possible that the fuel line is too close to the engine and the fuel flashes to vapor in the fuel line causing vapor lock. I recommend adjusting the fuel line if posible, and retry. Maybe replace that section of fuel line.
The other possibility is the ignition coil is going bad. You can check it by running the engine and when it stops, quickly remove the spark plug, caution hot. Put plug back into the wire and ground the spark plug and try to turn over the engine with the key start, if good spark, then the problem is likely the other,
I mentioned the fuel line first, because you said that you had been working with the carburetor, and the fuel line may be moved or a little shorter.
I hope this helps you get going soon.
Aug 16, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
What is the spark plug model number for craftsman YS4500 lawn mow
go to any auto parts store with your model info as they have a book which will tell them which spark plug is best for u.
Apr 16, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
149 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
