Question about Pool & Spa
Need manual for continental spa with infinity board and controls
What does "Firmware Rev B 13" n on indoor control panel? Help! Robert
The firmware message is the firmware on the wall mount control. The wall control would seem to be getting power, giving you the firmware rev only. Your communication with the main board has been lost, broken wire, main board has gone bad or for some other reason can not receive and instruction from the main board. If you have a spa side control, if spa side works then board may be ok, look for bad wire. If spa side is not working disconnect and power cycle the system and try the wall mount with spa disconnected. You may only need to replace the main board. More info on your system would be needed in order to suggest the proper replacement.
Sep 04, 2014 | Pool & Spa
Infinity maax hot tub
all systems must be working or the spa will not heat. If one of the sensors is not functioning then the spa water will not heat.
Rod
US Parts Center
Nov 25, 2013 | Home
Have an infinity spa and it has power to it but nothing will come on
Have you checked that the correct voltage is present at the board? If not it could a line in problem & GFCI breakers could be worn out. The power terminal on the board could be bad too.
You didn't mention the age of the spa but some older tubs will power up if the Hi Limit sensor has failed.
Or the board is dead.
There are a few alternatives;
Have a trained tech inspect the spa.
Replace the board
Send the board in for diagnosis or repair? There are companies who diagnose and repair spa packs/ boards usually for the same price as a normal service call. Spa circuit board repair.
Nov 11, 2012 | Pool & Spa
My Jandy Link control panel model 8157 turns on spa by itsself. It is not programmed to do so. Its says low battery. Can thisbethe cause?
No. Make sure there are no programs for the spa. Double check this. I assume this is a pool/spa combination. If so, check the valve actuators at the pool equipment. Do this by manually turning on the pool with your Remote control unit. There should be no water disturbance in the spa. If so, your valve actuators need to be reset. There is a metal toggle switch on the back of each valve that you can switch to set the valves to pool or spa.
*********** board at the equipment may also be the culprit. Try resetting it by pressing the small recessed reset button on the front of the panel with the tip of a pencil or pen. If neither of these slove your problem you probably need a new mother board. They are very expensive. Check to see if yours is still under warranty. Your builder can tell you this or you can email or call Jandy with your model and serial number found on the back of the board. Good Luck
Apr 18, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Brand spankin' new Master temp 400 NG,won't heat past 77° spa is set at 101°,pool at 88°, does heater pool/spa temps have to be manually set to max(104 i assume) for intellie touch to...
if the intellitouch is properly wired to the heater, it should all be automatic and you should be able to control it all from the remote.
there should be three wires connected to the circuit board behind the manual control on the heater (labeled "POOL", "SPA", "Common"). Those are the wires that the intellitouch uses to communicate with the heater.
You can download manuals from the Pentair website.
www.pentairpool.com
Aug 24, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Hot tub not heating need owners manual to reset
You need to provide the exact make and model of your spa
Dec 12, 2009 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Hot tub won't stay at set temperature
I have a 2002 Infinity 6 man spa that I just got from a friend. I am also an Electrician. I had to replace the Spa pack because it wasn't working. Once I replaced the Spa Pack and used the tub it got up to temp no problem but once I got in the temperature slowly dropped and it couldn't keep up. After some research and discussion with a pool tech I found out that there is a jumper on some spa packs. It is a LC (low current) / HC (high current) jumper. It limits the current (amperage) that your tub draws. If you are running it on the LC setting it keeps the tub at low current by not running the heater when the jets are on. (this way it keeps the current low by running one only at a time) If you set it for HC it will allow high current to be drawn and let the heater and the jets be on at the same time. On my spa pack it is P26 Jumper. I have found it is also listed as Jumper 4 on some spa packs. the jumpers are located in the lower right of the circuit board. Make sure you shut off the power to the tub and know what you're doing before you attempt changes. you can also google "Gecko Spa Pack Service Manual" and you will find the manual for your tubs spa pack. Good luck.
Nov 11, 2008 | Sport & Outdoor - Others
Pool & Spa Logo
59 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
