SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
SOURCE: For LG WM2233HW, Error Code OE. Already check
Replace the water pump. Because the water can not pump out, the machine idles for a while then stops with the error code OE. The technician said, the drain hose should be hang high before curse down to the drainage so air can not go to the hose.
SOURCE: I have a LG TROMM front loader washer(Wife's
Hi, ..,/.
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
SOURCE: OE code appears . There
Step by step solution with photos.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
SOURCE: My LG washing machine (Inverter 7KG WD-1274FB) has
Have you been able to test/see if the pump actually is free? Before considering a new one I would strongly advise doing so.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
heatman101
