Question about HP 920 Plain Paper Fax
How do I clear the memory on my HP 920 ..
It keeps printing old faxes from years ago and I can get it to stop
  • 10 Answers
SOURCE: Clear Memory
factory set
just list down all important settings stored at your unit..because all memory will be reset..
press " menu # 9000 * 550" then automatically restart.. reenter your previous settings
Posted on Jan 30, 2008
  • 168 Answers
SOURCE: HP 920 Fax Half Lines
Try making a copy of something.
If the copy comes out the same way as your faxes, then the ink cartridge is either dirty or clogged.
You can try removing the cartridge and checking the bottom of it.
You can even wipe the bottom of the cartridge with some denatured alcohol.
If this doesnt work, then purchase a new cartridge and your problem should be solved.
Good luck.
Hope this helps.
Mac =)
Posted on Apr 03, 2008
SOURCE: Fax Memory....
To reset memory problem you turn power off, then you hold down star and stop key ,then you will see on the display three options press option number 1 clear
Posted on Jan 05, 2009
leroyal
  • 2120 Answers
SOURCE: how to print fax stored in memory of HP fax 1040???
Unplug the power cord for 10 seconds.
Posted on Jan 16, 2009
SOURCE: HP 920 Fax History report information
How do I set it up so that a fax report is generated each time I fax something?
Posted on Mar 30, 2009
How do I stop my printer from printing memory clear report? so it can print.
Sign-in into printer (check the OM) and push "Stop Printing" or "Clean Printing queue" - depending on model.
Feb 19, 2015 | Canon Pixma Mx432 - Multifunction Fax /...
My fax machine cannon i sensys fax-l 120 is showing memory full. i cant recieve any fax. how i can clear memory
Hi
in order your fax to print you need to replace the cartridge
when the cartridge is low it stops printing incomming faxes
and keep it in mem untill you replace it with a new one
unfortunly this cartridge can not be refilled and use it
Hp is better on this
Jan 31, 2011 | Canon i-SENSYS FAX-L120 Plain Paper Laser...
The orange light keeps flickering. I checked to see if any paper is stuck but couldn't see anything. There's something preventing the printing process. What could it be? Need help. Thanks
hello
which one of these HP p/n's is your fax ? C4647A or C4649A
is this your fax ?
InkJet FAX-910/920 (C4647A) C4647A InkJet FAX-920 (C4649A) C4649AR, C4649A
InkJet FAX-910/920 (C4647A) C4647A InkJet FAX-920 (C4649A) C4649AR, C4649Apic00602.gif
go to this link , follow instructions, -- HW TO CLEAR PAPER JAM
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu50320&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=60718
please rate my service
Nov 05, 2010 | HP 920 Plain Paper Fax
Ran out of toner a week ago...stopped printing....did my print jobs and/or faxes go somewhere to retrieve later when toner replaced?
Your print jobs may still be in the spooler of the printer. Check the computer (Windows 7, Start > Devices and Printers. Windows XP, the title was Printers (IIRC)). The incoming faxes will be stored in memory; it can store up to 320 pages. (If you have other faxes in memory, the number of incoming faxes that can be stored will be less. Clear the memory after replacing the toner and printing the stored jobs. Press Menu until you see Maintenance then the left and right arrow to select the item to clear. Then press Enter to clear that area. When done, press Clear/Stop.)
I hope this helps.
May 17, 2010 | Ricoh AC205 All-In-One Laser Printer
I have a hp fax 920, want to take off covers to troubleshoot a no original feed problem. Where can I get service or parts manual. thanks.
I use to fix these years ago. Open the top cover, remove the scanner cover and remove two screws. The screws are located on the inside one on the right and another on the left, closer to the top of the unit. I believe you need a T10 screwdriver and you will have to pry the covers off pulling the right cover to the right and the left cover to the left. It's a little tricky just be careful not to break anything. This is an old unit good luck getting parts.
Nov 23, 2009 | HP 920 Plain Paper Fax
Trying to clear memory on HP #D1420
You need to clear the print queue in the printer properties.
go to start >printers and faxes > double click on your printer.
click on the word printer (on the upper left corner),when the window pops up. then scroll down to cancel all documents. This will clear the print queue.
Afterwards, power off the printer and the computer. wait 30 seconds, power up the printer, wait 30 seconds, then power on the computer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | HP PSC 2410 All-In-One InkJet Printer
Fax Memory....
Jun 30, 2008 | Sharp FO-4400 Fax
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
HP 920 Plain Paper Fax Logo
99 people viewed this question
Seeker5211
Seeker5211
