Question about Ecoquest Fresh Air Air Purifier
What does the sanitize mode do? - Ecoquest Fresh Air Air Purifier
  • 146 Answers
It is a cleaning mode
Posted on Jun 05, 2010
How do i remove the uv bulb
Place your finger in the door recess on the right-hand side of the sanitizer and pull open the door.
Remove the drip tray.
Remove the protective screen by gently lifting it up and pulling it forward.
To remove the UV light bulb, pull it out of the lamp holder.
Install the UV light bulb by snapping it into the lamp holder.
Align the pegs on the protective screen with the slots in the reflective surface of the sanitizer on either side of the UV light bulb.
Insert and gently push down the screen to secure it in the sanitizer.
Reattach the drip tray.
Dec 13, 2014 | Air Purifiers
Eco Quest Fresh Air
Have you unplugged it? Or is there a hard reset for it other than the reset button? Can you try to hold the power button down and see if that does anything? But try to pull the filter and stuff out again, after you have unplugged it, see if that works.
Mar 15, 2014 | Ecoquest Air Purifiers
No fresh air smell from EcoQuest Fresh Air 2.0. What is the fix for this? Everything else seems to work
The FA2 uses several technologies for purification. The "normal" mode produces purifiers using the honeycomb RCI cell and UV light. This has little or no odor.
Open the back of the machine, or shine a flashlight through the front to make sure the white 4" plate is inserted, closest to the back screen. If it isn't, you'll need to either put one in, or order one from Vollara (new EcoQuest company name) @ 1-800-989-2299. You can use #16618 as the dealer referral number if you are no longer in touch with the registered distributor who sold you the machine.
When you turn the machine to "purifier," you should then detect the "fresh air" smell. You'll see square footage numbers, which you should set according to the immediate area, NOT total for the building! Also, the machine directs the air flow to the sides in a "V" shape, rather than straight ahead. So if you're standing close to the machine, smack-dab in the front/center, you may not be able to smell any of the purifier!
When the machine is on "Away" mode, the purifier and fan are ramped up to maximum strength, and you can choose 2, 4, 6, or 8 hours for this super-sanitization. At then end of that time, the machine will return to whatever setting you had it on for daily operation. No people or pets should be in the immediate area, because the purifier is strong and likely to be uncomfortable. (Set the timer for 2 or 4 hours less than the time you expect to be "away," to allow the purifier levels in the home to return to a pleasant level.)
Hope this helped.
Jan 20, 2011 | Ecoquest Fresh Air Air Purifier
I have two ecoquest breeze and they are both around four years old. One just quit working, meaning the fan will not turn, the lights are still on, the other one the lights are all lit up but I cannot...
For the fan:
1) Unplug the machine
2) Remove the front grid.
3) Firmly but carefully pull the fan blades off of the shaft, holding toward the center of the fan, not the blades.
4) Use a light household oil (3-in-1, sewing machine, hair clipper) and put a drop or two on the shaft while you turn it manually. Do this until you feel the shaft moving easily.
5) Leaving the front of the machine open, turn it on and see if the shaft turns. If it doesn't, unplug it again, and continue working small amounts of oil down the shaft and then seeing if it turns.
6) Replace the fan. Turn the machine on, and give the fan a spin if it doesn't turn on immediately.
That should do it for that machine!
The other machine may be set on "Sanitize." This means that it will run at top capacity for 2 hours. Push the "Sanitize" button to deactivate it, then adjust the controls for daily operation. If this doesn't solve the problem, the issue is most likely with the computer system itself, and we can't do anything about that! Unfortunately, Vollara (new name for EcoQuest) no longer services or sells the Breeze. However, there are some options for upgrades and/or trade-ins. Call Customer service (800-989-2299) for options. Use #16618 if you need a referral number.
Jan 17, 2011 | Ecoquest Breeze AT Living Air Purifier
I just purchased a used XL15s. The unit when in manual mode emits an oder, but the air feels oxygenated. When you breath close to the machine the air seems to irritate or kinda burn my eyes. When in auto...
This is what the machine is designed to do! The machine emits a low amount of ozone, which is the purifier/sanitizer created by sunlight. Close to the machine, it's concentrated. When it spreads throughout the room, it kills odors and bacteria, and creates the fresh smell of clean air. The air truly is "oxygenated," because ozone is simply O3, instead of O2, and breaks down quickly.
If the numbered dial is set too high (try it at 300 to 500) it will smell "bleachy." Your "rule of thumb" is that when you've been away, and enter the home, you should experience the same fresh, clean smell that you get when you step outdoors on a bright spring or winter day.
When you're doing something that creates odors, like frying fish or cooking sauerkraut, turn the dial up to take care of that odor quickly, then turn it down for normal operation.
Leave it on the manual setting for continual purification. Often, the auto setting has been disabled, which might be the case in your older machine. (These machines can be 12-15 years old!) For an owners manual, go to www.vollara.com (new name of Ecoquest/Alpine). They may be able to help you.
Jan 17, 2011 | Alpine Air XL-15 Air Purifier
I have 2 ecoquest fresh purifiers 1 will not power on would that be a fuse issue and the 2nd the sanitize mode won't work would that be a starter balas(ms)???can you help???
I would certainly check the fuse on the one that does not power on. If the fuse is good then there probally something wrong internally.
As for the one that does not sanitize, has the plate been cleaned? It can have a build up of dirt on the metal grid and or the contacts that will cause it not to generate ozone. The plate and contacts can be cleane with an amonia solution of one part amonia and one part water. Soak the plate in the solution for 10-20 minutes then scrub with an old toothbrush, and rinse the plate with tap water. You can clean the contacts with the amonia solution using a toothbrush. Allow the plate to dry overnight or you can use a hair brush to dry thoroughly.
Nov 17, 2009 | Ecoquest Fresh Air Air Purifier
Flashing blue lights
toss it. learn from it. Use Consumer Guide or something similar. Thank god it fots down the incinerator duct.
Jul 28, 2009 | Sharper Image Professional Plus Ionic...
My flair works o.k. except the santinizer doesen't work. I have one ozone plates that is broke on the corner of the plates and there is a black line running through it. Could this be the problem?
The ozone plate will not cause the sanitizer button to not work but it may have caused the button to short out. The sanitizer switch probably needs to be replaced. The plate definitely needs replacing, when there is a crack in the plate it causes an electrical arc which is burning the black line onto the plate. Please remove and throw away that plate.
Jun 07, 2009 | Ecoquest Flair Air Purifier
Smell in the air
If the smell is not electrical as JEShandyman was asking, but rather from something trapped in the lint filter you could try putting the unit under a box and put it on sanitize. Let it run for 30-60 minutes and see if that cleared up the problem. Washing and drying the filter first is a good idea.
You should never get a head ache from the smell the machine produces. The fresh air the machine produces reacts with the odors and contaminants in the environment and that can potentially create other smells. If that happens you should scale the machine back to a lower setting and take it very slowly and ramp it up day by day. This is something you should have been told by the person who sold you the machine to begin with.
I hope this helps.
Eric
Nov 12, 2008 | Ecoquest Breeze AT Living Air Purifier
How do you know if it is working (fresh air) Ecoquest?
I don't know if I'm allowed to post a link or not, but I'm giving it a try.
Here is a link to the .pdf for the product manual for an Ecoquest FreshAir unit:
http://www.ecoquestintl.com/dlrdown/website_om/faom_62-00230.pdf
This is the one that has the 'away' mode on it.
Here's the main website where the product manual link can be found, it may help you find your other manual:
http://www.ecoquestonline.net/retail_products/fresh_air.asp
Hope this helps!
susanszy
Nov 10, 2008 | Ecoquest Fresh Air Living Air Purifier
Ecoquest Fresh Air Air Purifier Logo
147 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
