Question about HP Pavilion dv4000 Notebook
Is there any sata slot available on HP Pavillion dv4000 laptop, i mean can i install a sata hard disk in my hp Pavillion dv4000 laptop?
  • 1,675 Answers
Hi this depends on the age if it is older than 3 1/2 year old approx, then you maybe able to put one in, other than that the easiest way to find out is to take the old one out, just look at the back end where it connects to the board, if it has pins in the back its ide if it has just a line of contacts then its sata...hope this helps
Posted on Jun 05, 2010
If my HP pavillion g4, self test says "hard disk
pjotobey:
The message "Hard Disk Failure" is what is called a "Fatal Error" it means that some component in the hard disk has stopped working for some reason. The hard drive in your machine will have to be replaced.
Mar 16, 2013 | Computers & Internet
How to install second hard drive in HP P7 1107c
  • Stick the HDD into an available slot in the chasis
  • Connect an available sata power cable from your PSU to the HDD
  • Connect a sata data cable from the drive to an available sata port on the motherboard
  • Close the case and power on the computer
  • Right click My Computer/Computer and select "Manage"
  • Go to Disk Management and locate the drive (Disk 1) most likely
  • Right Click it and select "Format" choose your partition type and format.
  • Create one or more partitions.
Jul 13, 2012 | HP Computers & Internet
I have a hp pavilion dv4000 laptop but dont have restore disk
The hard disk has died, replace it and reinstall windows using someone's else disk and your key.
Mar 28, 2010 | HP Pavilion dv4000 Notebook
I need buy the hard disk drive to my pavillion dv4000.
You can buy 320 Gb hardisk which compatible with evry laptop.
Nov 04, 2009 | HP Pavilion dv4000 Notebook
HP Pavillion dv4000 is stuck with a 'disk read error'
try with Disk Manager so Format with Low Level Format...run in under DOS
Oct 23, 2009 | HP Computers & Internet
My hp pavillion dv4000 wont load the operating system
Try booting your system in safe mode.
  1. Reboot
  2. press F8 continuosly while it reboots until you get options asking how you want to boot up.
  3. Choose safe Mode w/ networking
  4. If it reboots fine than that tells us itcould be a possible hardware issue.
If it still has issues booting up than It could be that your system files on your operating system may be corrupted. Try fixing your XP installation files with an XP disk if you can.
Mar 09, 2009 | HP Pavilion dv4000 Notebook
Transfer data from a dead laptop to a new laptop
Do you have a usb to SATA connector? If so you can plug the old drive into the USB slot and it will act as a slave so you can pull the contents from the old drive to the new. The adapter is about 25.00 or If it was me I would invest into a pocket USB hard drive case that you can put your old drive into perminatly so you can always have a external hard drive for back up later after yo uhave moved the data over and reformatted it. The case is $25-$40.00.
Joe
Jan 16, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Faulty Connection
I have HP DV6000, I used it without the battery. it worked until I was able to purchase a new battery. It might work on the HP dv4000...
Jan 05, 2009 | HP Pavilion dv4000 Notebook
When starting my DV4000 - the screen is dark other than a cursor in the left corner.
That error indicates a hard drive problem. You probably have to replace the hard drive.
Nov 23, 2007 | HP Pavilion dv4000 Notebook
Unable to install Windows XP on HP Pavillion DV2000 ( Built in Vista )
Best Solution is to disable Native SATA support in BIOS ,
Now Win XP will recognize the Hard Disk
Sep 05, 2007 | HP Compaq Presario V2000 Notebook
HP Pavilion dv4000 Notebook Logo
171 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
