Question about Olympus STYLUS TOUGH 8010 Digital Camera
Lens cover stuck closed on Olympus Tough 8000
The lens cover is stuck closed on my Olympus Stylus Tough-8000. The splash screen comes on, but it beeps 12 times and the lens cover doesn't open. Stopped working in the middle of taking pictures in a clean and dry environment, but it was used in a chlorine pool the day before. Have tried compressed air and vacuuming - no change.
SOURCE: the lens cover on my olympus stylus 770sw is stuck
I have a u770 with a broken lens. I would like to either buy yours to repair mine or I am willing to sell mine so you can repair yours. Email at (g4)(kpp)@(hotmail).(com) - remove the brackets - trying to avoid spam
Posted on Mar 17, 2010
SOURCE: lens stuck
hnggg
Posted on Feb 20, 2008
SOURCE: Jammed Lens - Olympus Fe-330
I called the store I bought it from, as well as the Olypmus toll free number. They both told me I had to mail my camera to them with a brief description of the problem. It is still under warranty, but I have to pay for shipping to get it to them. They will repair it and send it back to me. Do not try and fix the camera yourself, instead get it fixed professionally with all the proper tools once and for all.
Posted on Mar 19, 2009
BillB-SA
  • 2761 Answers
SOURCE: olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
  • 699 Answers
SOURCE: microSD atchment write protect
The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
Hope it helps: let me know how you go!
Posted on Mar 07, 2010
My Olympus Tough 8000 charges up to a blue light but when I unplug the charger and switch it on, it just beeps multiple times and switches straight off. I've only used it for a week and it's a new,...
i have the same problem too. Mine is mju tough 6010 and it just beeps and switch off. The metal cover in front of the lens won't open. Mine is just 1 month old.
Aug 27, 2010 | Olympus Mju Tough 8000 Compact Digital...
I CANNOT OPEN THE LENS OF MY CAMERA. OLYMPUS TOUGH 6010. There''s a beeping sound everytime I open it. I can only view the pictures but I cannot use the shooting modes.
Apparently some problem in the inside of the camera with the lens assembly or something is disconnected. You can get in touch with the repairs of the Olympus company and see what repairs would cost. I am almost sure that the repair is going to be more than the camera is worth to you.
Many times dirt or dust can cause problems with the lens. Also this can be caused by internal problems which means repairs. In my experience with these small cameras, the lens repairs have been some of the hardest repairs to complete correctly. That is not saying that it cannot be done. If the lens is taken apart or removed, the camera should be re-calculated on a computer with the right software.
Apr 15, 2010 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
It wont turn on to take pictures, it wont boot up. but it will turn on when you want to review the pictures you took.
I experienced the same symptoms, with the exception that the lens cover wasn't opening correctly (I'd boot up to review mode then try and enter shoot mode from there [by turning the dial] in order to see if it was a battery or circuit board issue). I was seeing that the lens cover wasn't closing the full way when the camera went to auto shut off after this procedure. The solution to my problem was as per the below Olympus link:
Lesson learnt: The lens cover motor workings need TLC and should be opened and closed whilst immersed in fresh water periodically to remove any debris, and that the camera is sensitive to issues with the auto lens cover.
http://www.olympus.com.au/content/view/177/78/
Mar 23, 2010 | Olympus Mju Tough 8000 Compact Digital...
Lens cover stuck open. Can't take photos but can review old ones.
I have the same problem. Have you come across a solution? It's definately my lens and not my battery. Where did you go to get the lens looked at and repaired?
Jul 07, 2009 | Olympus Stylus 770 SW Digital Camera
The cover over the lens is two pieces. The top one open and closes properly but the bottom one is stuck in the open position leaving the lens unprotected when the camera is off.
Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $86.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 14, 2009 | Olympus Stylus 740 Digital Camera
Lens won't come out
It sounds like the sensor that tells the camera weather the cover is open or closed has failed or come loose. This is a fairly common issue on cameras with the sliding lens covers. Our shop would charge around $50 in labor to fix this issue if it is that sensor. If a part was required it would be somewhere between $20 and $50 depending on what Olympus charges for the part. Cannot speak to what other shops may charge. David Millier Advance Camera Repair
Feb 22, 2007 | Olympus Stylus 410 / ? 410 Digital Camera
Olympus STYLUS TOUGH 8010 Digital Camera Logo
567 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
